0 members (), 346 guests, and 34 robots.
+8Rich 94
Posts837,276
Page 3 of 4 1 2 3 4
I have a Hilka 2 ton jack maybe 20 years old. Its lift is 23cm but I think it used to be more. No signs of leaking oil. There are two plugs one slotted which seems to have some kind of adjustment slot under it & a hex plug which seems to be the oil reservoir & seems full. Any thoughts on how to increase the lift?
Tim
Perhaps it needs to be bled? If air has crept in....
Richard how would I bleed a jack?
Tim
Tim
Punch him on the nose.
Best Regards
Lang may yer lum reek
There is probably a screw near the top of the cylinder you loosen to let out the air.
May I ask another relevant question. Where would you place the trolley jack on the rear chassis to lift a back wheel? I have a 2009 Plus 4
There is a cross member at the rear of the chassis that is the preferred place to
Lift the rear of the car.
My 2011 plus 4 has a painted panel which has the rear fog light and reversing light moulded into it which covers this cross member, so I choose to use raise the car on the differential. Others will say not to use raise the car on the diff. For the few times that I have had to raise the car at the rear, I prefer to do it that way rather than damage the body coloured painted area covering the cross member.
The choice is yours.
Ian
Thank you
I use the diff
Posting Desperado
Posting Desperado
You can purchase a jack pad , its a rubber pad that pops over the head of the jack . I think Machine Mart has them stops any damage.
Page 3 of 4 1 2 3 4
