4 members (JohnHarris, Ruut Bianchi, BobtheTrain, MartO), 198 guests, and 77 robots.
Topics49,848
Posts837,406
DazMog, The Impaler, tlchzj79
Page 2 of 7 1 2 3 4 5 6 7
Originally Posted By ItsJustMe
Not to be snarky, but consider a Toyota instead.
Don't rush to that Toyota dealer just yet. Buy an EV3.
No V-twin racket to drown out that audio, and just think of the size of the amps you could run off that massive battery.
laugh2
Stuart
A 3wheeler is no hihgway tool and all other streets will restrict you to lower average speeds than a 1000 mile day drive would require.
When I was younger I did Bucharest/Vienna several times within a day. 1250km (less than 1000miles!) and only 100km of highway that time. Drove a 3liter BMW and needed 13 to 16 hours at speeds far above legal speed limits...
I would not recommend to do that distance in a M3W.
And I wonder if a Mog3W would survive 16 hours at an average speed of 60miles/hour
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
600 odd in a day is not a problem , been there done that
kirkusblog.com
1952 Ford 8N
le Asbo du Bling
le Asbo du Bling
Snap, longest I've spent in a 3 wheeler has been about 14 hours on the Nordkapp trip.
If you're going to be doing anything above town speeds then you'll need some ear protection just to keep the wind noise levels tolerable. I've got a pair of molded ear plus fitted with a decent set of head phones which is plugged into my iPhone.
The provides some music on the move and helps reduce the wind assault on the ears. If I do more than a hour at speed in the 3 wheeler my ears are ringing for hours afterwards.
Slowly going green
The three wheeler is equipped with its original HD, must be varied the accelerator pedal to set the sound.
headset seems like a bit of a mistake if it cancels out all outside noises as that would be extremely distracting. I dont mind it for a racetrack, rally, etc. But using in both ear speakers is not wise for the road.
I am quite sure a beats or otherwise blue-tooth speaker set would be plenty loud even at speed. Are you going to have symphony quality sound at speed...no, but you could still listen to music. Plus, at idle it would most certainly be loud enough. Putting around town something like this would be perfect.
Ideally you would get speakers custom placed into headrests as the proximity to your ear will matter, but thats a whole nother level.
kirkusblog.com
1952 Ford 8N
Originally Posted By twotribes
...Buy an EV3.
laugh2
Presumably you'd need a small trailer for the Honda portable generator, unless one can fit on the luggage rack! Hmmm... range extender, Morgan-style! wink
Originally Posted By Waldemar
You will have two exhaust pipes, that is enough stereo for europe listening
+1 (or should that be +2 for stereo?)
Red Leader drive
