1 members (yobtaf),
343
41
Topics49,860
Posts837,486
Posts: 1,948 |
Not to be snarky, but consider a Toyota instead.
Don't rush to that Toyota dealer just yet. Buy an EV3. No V-twin racket to drown out that audio, and just think of the size of the amps you could run off that massive battery.
Stuart "There's no skill substitute like cubic inches."
Posts: 5,017 Likes: 3
Posts: 5,017 Likes: 3 |
A 3wheeler is no hihgway tool and all other streets will restrict you to lower average speeds than a 1000 mile day drive would require.
When I was younger I did Bucharest/Vienna several times within a day. 1250km (less than 1000miles!) and only 100km of highway that time. Drove a 3liter BMW and needed 13 to 16 hours at speeds far above legal speed limits... I would not recommend to do that distance in a M3W. And I wonder if a Mog3W would survive 16 hours at an average speed of 60miles/hour
Posts: 245 Likes: 5
Posts: 245 Likes: 5 |
600 odd in a day is not a problem , been there done that
Posts: 2,539 |
Posts: 3,838 Likes: 9
le Asbo du Bling Talk Morgan Addict
Posts: 3,838 Likes: 9 |
600 odd in a day is not a problem , been there done that Snap, longest I've spent in a 3 wheeler has been about 14 hours on the Nordkapp trip. If you're going to be doing anything above town speeds then you'll need some ear protection just to keep the wind noise levels tolerable. I've got a pair of molded ear plus fitted with a decent set of head phones which is plugged into my iPhone. The provides some music on the move and helps reduce the wind assault on the ears. If I do more than a hour at speed in the 3 wheeler my ears are ringing for hours afterwards.
Slowly going green
Posts: 786 Likes: 18
Posts: 786 Likes: 18 |
The three wheeler is equipped with its original HD, must be varied the accelerator pedal to set the sound.
Posts: 836 |
headset seems like a bit of a mistake if it cancels out all outside noises as that would be extremely distracting. I dont mind it for a racetrack, rally, etc. But using in both ear speakers is not wise for the road.
I am quite sure a beats or otherwise blue-tooth speaker set would be plenty loud even at speed. Are you going to have symphony quality sound at speed...no, but you could still listen to music. Plus, at idle it would most certainly be loud enough. Putting around town something like this would be perfect.
Ideally you would get speakers custom placed into headrests as the proximity to your ear will matter, but thats a whole nother level.
Posts: 2,539 |
Posts: 1,815 Likes: 32
Posts: 1,815 Likes: 32 |
...Buy an EV3. No V-twin racket to drown out that audio, and just think of the size of the amps you could run off that massive battery. Presumably you'd need a small trailer for the Honda portable generator, unless one can fit on the luggage rack! Hmmm... range extender, Morgan-style!
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
You will have two exhaust pipes, that is enough stereo for europe  +1 (or should that be +2 for stereo?)
Red Leader
