1 members (scortroadster), 299 guests, and 97 robots.
+8Rich 77
Topics49,870
Posts837,667
Rudolf
Page 4 of 14 1 2 3 4 5 6 13 14
Tim W #357305 19/04/16 02:45 AM
Welcome from the Colonies Tim W ... wine
Tally Ho ! thumbs cheers
Suggested kit ... drive
2013 M3W # 793
'Mosquito'
Tim W #357317 19/04/16 05:55 AM
That's tight. Luckily the M3w has no doors! Classy, looking vehicle. Hope they find the cover as they are not cheap.
Robert
Tim W #359288 26/04/16 08:42 AM
Sheepskin hat looks identical to the one I have just received from FurHatWorld. Ticks all the boxes, good price and less than a weeks shipping from Canada to UK smile
Tim W #359304 26/04/16 09:14 AM
Don't ley Jays see that website. He won't like the fingerless gloves
http://www.furhatworld.com/fingerless-rabbit-fur-knit-gloves-brown-p-4068.html
Tim W #359355 26/04/16 12:32 PM
Like the scarf! Though I'd be afraid it would snag on something and rip my head off. Probably unlikely. 1 in 3 tops.
RichardV6 #359390 26/04/16 02:42 PM
Indeed it is, Richard ! Tally Ho ! thumbs cheers
Nick, Tibetan silk, 6' long, I only let a little out for just that reason ... drive
2013 M3W # 793
'Mosquito'
Tim W #360528 30/04/16 11:41 AM
Tim W Offline OP
Krazy Horse fitted the Fairbourne windscreen to Thumper, but I was not totally convinced by the fit and finish around the bonnet
The older Morgan's have a metal support for the windscreen, so I thought that duplicating this would be a good way to hide the joint and maybe make it a little more weatherproof. So I got some 20 x1.5 mm stainless steel strip and tortured it into a compound curve using a mangle with gear driven rollers with narrow, deep, slots to restrain the strip in the axis it really wanted to bend. The stainless steel strip put up a valiant fight but was eventually persuaded to bend and actually took on a lazy Z shape from the edges of the rollers. I wouldn't want to make another pair!
The strips were drilled to clear M3 stainless steel Allen screws and attached to the windscreen. The strips look tidier than I expected from behind and the front. I have some self-adhesive rubber strip which could be used to hide the back and make a seal, but I may not bother with them.
Took Thumper out for a spin in the sun and the windscreen worked perfectly....
Tim
Tim W #360529 30/04/16 11:54 AM
That looks like the making of an after market item - superb work!
Tim W #360530 30/04/16 12:26 PM
I think you will find a need for a seal of some sort. Rain tends to run down the screen, into the mounting and then onto your legs. It also comes in the centre where there is a gap. I was surprised at how dry you can stay in the rain with the Fairbourne screen, as long as long as you keep moving. The trim looks good.
Richard - Aus #360556 30/04/16 02:15 PM
SBM Offline
Too true!
Very professional, well done.
