Morgan Aero 8
0 members (), 273 guests, and 81 robots.
+8Rich 76
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,873
Posts837,707
Matt C #36121 14/10/09 03:11 PM
My understanding that most xenon headlights can be easily adjusted to suit either LHD or RHD - usually some sort of mechanical adjustment.
In fact with some current Audi models (S5 being one) it is possible to do it from within the car using the MMI system.
However regardless of this there should be a means of adjusting at the headlight as IIRC it is the position of the shutter that determines light spread.
The factory will I imagine provide the definitive answer.
Rbt Aero8 thumbs
Rbt Aero8 #36136 14/10/09 06:41 PM
We sorted the lights for Speedmog he has an S1 that went to Portugal.. no problems and pretty simple job... just requires two units..
PM for details
Yep the headlights was a straight swap. You also might need to swap over the fog and reverse lamp at the rear. This is also relatively straight forward as the std loom caters for either LHD or RGD. Just look for the spare lead and swap plugs and lamp units over.
Phil Egginton
1979 4/4 4 seater
