0 members (), 257 guests, and 86 robots.
+8Rich 77
Topics49,870
Posts837,668
Rudolf
Page 8 of 14 1 2 6 7 8 9 10 13 14
Tim W #361423 04/05/16 08:16 AM
Originally Posted By Tim W
Agreed that getting wet is an occupational hazard with an M3W, but the Fairburn screen does deflect the rain better than the supplied slit screen. The water driving through the gap in the middle at the bottom can be stopped... I think....
Tim
You need a short length of closed cell foam for the gap. I bit of experimenting with width will close the gap & not be too noticeable. I find you need to be more scrupulous in keeping the Fairbourne screen clean
Tim
Tim W #371834 19/06/16 03:45 PM
Tim W Offline OP
In the rain yesterday the front seal on the Fairbourn windscreen did a good job of stopping water coming in through the front (at speed) which was appreciated by my little co-pilot Max.
Went for a Father's Day jaunt with middle son today. Just fitted the 280 mm fuel sender and went from 27% empty to 70% full. Nice to know that the fuel gauge is now a bit more truthful. Also took the opportunity to clean up the rear (not very dirty) and check out the belt and new rear steel sprocket: all ticketyboo.
Tim
Tim W #371848 19/06/16 05:03 PM
HJP Offline
Pleased to see Max enjoys the car too Tim , and glad it's all going well smile
Hugh
Hugh
Tim W #372022 20/06/16 05:18 PM
Hows the new steel sprocket?
Tim W #372026 20/06/16 05:27 PM
Sidelights are on !
nippymog #372034 20/06/16 06:01 PM
Originally Posted By nippymog
Sidelights are on !
That's OK, the dogs got his shades on. They will have gone out by now anyway, it was at least 24hrs ago.
Tim W #376221 09/07/16 07:59 PM
Tim W Offline OP
Mounting a mobile phone in the M3W is a bit challenging, but would be useful when using it as a GPS. I purchased one of these recently but couldn't find anywhere to put it where it didn't look pig ugly. Might be OK in the new motorhome that we get next week.
The actual holder was quite neat however. So I turned up a stainless steel bolt with a knob on it.
This goes in the passenger dashboard and looks fairly inconspicuous.
With the attachment in place it is a bit less pretty, but that can be removed easily and stowed under the dash.
No point Robert (Grockle) doing this modification, as he won't have signal coverage in N Devon & Cornwall!
Tim
Tim W #376223 09/07/16 08:16 PM
Drive on the Wild Side
For future reference try a Steelie no drilling and can be removed, and buy extras to use in other cars, simples!
Adrian
Tim W #376227 09/07/16 08:26 PM
Tim W Offline OP
I did look at those Adrian, but don't want a magnet on my phone. The dash already had an M6 fixing hole - I simply replaced the bolt.
Tim
Tim W #376230 09/07/16 08:40 PM
Tim
Curious... Why the objection to a magnet? The magnet is in the mount anyway and it's a razor thin steel plate on your phone or case.
The Original Ken
11,000 miles.
2014 BMW R9T
2005 Saabaru
2005 Saabaru
