1 members (Daniel Craig), 290 guests, and 43 robots.
+8Rich 94
John V6 49
Posts837,991
rockabilly john
#361593 04/05/16 08:38 PM
I'd like to put the car on axle stands in the garage while I do some work, what are the safe points to use?
1983 Plus 8 (on carbs)
1975 Land Rover 109" full tilt
1989 Caterham
1999 Honda Fireblade
The official lifting points are at the front the lower cross tube. At the rear the rear crossmember right at the back.
On a four point lift, dealers seem to use the bulkhead corners at the front where there is a triangular chassis section. At the ear they use the big crossmember which houses the front hangers of the rear springs.
I use lifting beams front & rear so lift one end at a time centrally - axle stands under the front lower cross tube.
At the rear I leave the beam in place and put an axle stand at each end.
But Alternatively I used wood blocks under each wheel.
Be very careful when you lift each end because a trolley jack can cause the car to move forward/backwards and it could come off the stands very easily.
Here are the recommended points as mentioned in graphic form.
http://www.gomog.com/allmorgan/jackpoints2.html
Needless to say this all goes out the window at the roadside wink
Do be careful that the chassis is sound where you put the axle stands before you get underneath thumbs.
DaveW #361651 05/05/16 05:10 AM
This is a very important point. You want your trolley jack to move rather than the car when lifting the second end. Make sure the trolley jack is longitudinal with the car and free to roll on the floor. I sometimes used a sheet of ply on the floor to provide a smooth surface for the jack.
The bigger the trolley jack, the less pronounced this effect is, as the radius of the arc through which the lifting pad moves is greater.
Hamwich #361780 05/05/16 02:01 PM
Originally Posted By Hamwich
[quote=DaveW]
I recently jacked up a 2005 Roadster from the back. Too high and it rolled off the jack, damaging the "Vapor Canister" $400US. I would jack each end a bit and place jack stand then jack the other end a bit and place jack stand.
I am also retiring as a "Back Yard Mechanic" trying to help others. Obviously I am not qualified.
Button
Seattle
Button
