New
Topics48,366
Posts813,390
Members9,215
Posts: 853 |
Stick it in a saucepan of warming water with your jam thermometer and see when it switches - add a couple of flying leads first and connect a meter on continuity or batteries and a lamp if you don't have one. Make sure the otter switch head is immersed and not in contact with the pan at all.
Probably somewhere in the range of 82 - 98C. Now why didn't i think of that, thanks
Ken A. Plus 4 2009 Centenary Metallic Red Plus 8 1994 Dark Green (prev) Honda CB100 The Big One
Posts: 2,272 Likes: 7
Posts: 2,272 Likes: 7 |
Ken
My original +8 set up was secured by a thin wire through the radiator and the bottom tank (several wrappings) , as per Colin's suggestion. I didn't like it one bit, so was doubly pleased that when I changed to Mulfab alloy radiator, and there a proper boss into which the switch screws securely.
You car deserves an alloy radiator anyway, you know it makes sense.
Posts: 463 |
Sounds like you have the same setup as the later model MGB, once the seal perishes the switch pops out, later on they added a stainless clip. I think your going to be better off in the long run with the brazed in housing.
Dave 98 +8 Corsa Red 74 MGB Red
Posts: 5,181 Likes: 2
Posts: 5,181 Likes: 2 |
cable tied mine in. When the rad was cold it could be pulled out by hand.
Posts: 514 Likes: 1
Posts: 514 Likes: 1 |
http://www.talkmorgan.com/ubbthreads.php/topics/290395/Re:_Verify_temp,_and_gauge_cal#Post290395
About halfway down the threads, seems a common problem....
Malcolm T 1966 +4 1957 TR3 1963 TR4 1983 LR 110 1985 Robin Hood 2.0l
Posts: 853 |
Many thanks for all comments and suggestions. For the time being I am fitting a replacement rubber seal and lock wiring the thermostat to secure.
