8 members (Image, Chris Cosher, planenut, Montegue, Zach, RichardV6, JohnHarris, Morganmike),
305
Posts838,001
Posts: 5,549 Likes: 67
Posts: 5,549 Likes: 67 |
I have to say that I'm firmly in the Yes camp when it comes to greasing. It's a good chance to have a run around with the spanners and give everything a wipe down. You also get to grease the spines and check the inside edges of the tyres.
Posts: 1,943 |
I am too old to crawl on my belly to get my KP's greased. That is why I don't. And have not for about 20 years.
Button Seattle
Button
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
Greasing overrated SPORT.
Posts: 37,479 Likes: 988
Posts: 37,479 Likes: 988 |
Greasing overrated SPORT. Well you do get a double dose  of it.
Posts: 853 |
Just about to do my first greasing, glad for all the info on this forum but not at all sure about the damper blades, still, once I get under there I am sure it will all be obvious?
Ken A. Plus 4 2009 Centenary Metallic Red Plus 8 1994 Dark Green (prev) Honda CB100 The Big One
Posts: 22,370 Likes: 354
Posts: 22,370 Likes: 354 |
You can't miss them if they are there Ken. Look for a piece of spring steel between the stub axle leading back to the chassis.
Posts: 1,213 |
Thanks for posting that picture , I've often wondered what they look like !
Hugh
Posts: 853 |
Which "end" needs prising up, I assume it will be the end with the hole?
The end with the hole. You won't find a small jam jar though.
