6 members (howard, PaulJ, IcePack, Alan Patterson, AlyMatt, How), 303 guests, and 84 robots.
Topics49,849
Posts837,410
DazMog, The Impaler, tlchzj79
Page 2 of 5 1 2 3 4 5
I'm trying these to see if they're viable - Harley detachable screen clamps - but filled with ring bolts or eye bolts for the rack to slot into.
Ill also use some Velcro straps wrapped around the locks to ensure they're always kept in the over centre & locked position
These look interesting and just might do the job in a very slick manner...
http://www.summitracing.com/parts/aaf-all99161/overview/
These look good but the lug is at 90 degrees out of orientation to where it needs to be.
I think the Lug turns - you can just see the holding screw from the pic - these are what I tracked down - but never bought.
Neil
Did your kit come with a block of wood, mine dod and I have no idea what is for
kirkusblog.com
1952 Ford 8N
It's a swivel mount. Just ordered. Talked to tech support and the swivel inner diameter may need to be enlarged a bit but that is not a bother. It is more than adequate to do what needs to be done. A mounting bracket for my golfing umbrella, or as I like to call it, my roof. It will occasionally be used to actually carry stuff but not too much.
Nice one guys - Looks like all our ideas will be R & D initiatives for MMC to review.
I look fwd to further developments & photographs.
No one has come up with a front mounted bonnet rack 🙄 Or mono wheel trailer.
Cool, i need a set of those! I was squeamish about drilling that hoop. Wifey was mortified!
kirkusblog.com
1952 Ford 8N
Bonnet rack? oy
I just saw a new Polaris Slingshot with a trailer hitch! He pulls a bike trailer with it as the Slingshot has as much storage as the M3W... none. It was mounted to the rear frame above the swing arm. It's wide open back there.
I don't think that would be possible for the likes of us. Anything that would mechanically work would very likely be ugly as sin...
Bonnet rack? oy.
Michael...you're Irish too?
