0 members (),
271
40
Topics48,341
Posts812,981
Posts: 206 |
HI Laurens, did you press the black button? The "accident switch" could be activated after a strong ride or a "hit". Just press it and find out if the M3W starts after it. Sorry i have only a picture of the part from my ARP4 (my M3W is on service) The black part with the soft surface in the middle of the picture - the same part in M3W... Good luck - Thorsten
Posts: 3,658 Likes: 48
Posts: 3,658 Likes: 48 |
It's the inertia cut-off switch and on the M3W is in front of the battery on the right hand side partially under the oil tank. Press the rubber top and if you hear and feel a click that's probably the issue.
Red Leader
Posts: 582 |
I NOW carry an extra fuel pump. Never leave home without it, Also carry a Harley rectifier and enough tools to do the install on both
Posts: 1,338 |
FUEL PUMP & RECTIFIER! I hope for long trips only. not whenever you take it out for a spin
Posts: 712 Likes: 8
Posts: 712 Likes: 8 |
Today same problem again. Didn't start. No fuel pump sound. After 10 minutes the pump suddenly run again. Went home, switched the engine off once during the trip ( no problem to start ) when home switched off the engine and try to start again but no fuel pump sound, so couldn't start. After half hour without touching the car still no fuel pump. I left the car without touching or move it. Waited one hour more, turn on key and the pump was running again. Uhhhhhh. What can make this problem ??
Posts: 1,338 |
Check the wires, but as you said at times i guess the fuel pump is going.
Posts: 655 Likes: 1
WW11 MOG Talk Morgan Regular
Posts: 655 Likes: 1 |
First of all get the fuel pump pressure checked. Should be about 58psi...mine was 10psi
My fuel pump also had a loose connection on the pump - within the fuel tank. Might be worth removing the pump and having a look if the pressure is ok. There are good descriptions of how to remove a pump on here
If all ok I would get the ECU checked
Posts: 103 |
Went home, switched the engine off once during the trip ( no problem to start ) when home switched off the engine and try to start again but no fuel pump sound, so couldn't start. After half hour without touching the car still no fuel pump. I left the car without touching or move it. Waited one hour more, turn on key and the pump was running again"
Had the same problem , turned out to be a bad earth on the earthing bar located behind the seat back (2012 version) made good since then no problem.you could try putting another earth on the pump to see if that clears it.
