Posts838,002
Posts: 27,838 Likes: 763
Posts: 27,838 Likes: 763 |
Steve I know but it works really well & has a long hose to it so fitting is easy The car drove much better after, of course that could just be imagination.
Too powerful I am sure for the UJs but a great help at the front. Now I need a small grease gun for touring.
Posts: 159 Likes: 1
Posts: 159 Likes: 1 |
Is there a particular part number for the remote greaser from the Nipple Shop ?
I'd like to see what's in the kit and see if I can get something comparable on our side of the pond.
Dutch Junge 194 Mound St Logan, OH USA 43138
2012 3 Wheeler 1980 + 8
Somewhere on here is that info. Use the search function.
Posts: 5,442 Likes: 133
Black Rat Charter Member
Posts: 5,442 Likes: 133 |
Why not just order a kit from Cain @ Wolf Performance ?
Posts: 834 Likes: 28
Posts: 834 Likes: 28 |
Dutch, you may wish to enquire if the remote greasing kit is suitable on damper blade models, there was fouling on my 93 plus 4.
1993 T16 +4 Lancia Blue.
Posts: 504 Likes: 2
Posts: 504 Likes: 2 |
Yes, the kit is now compatible with damper blade models. The former version was not, the bottom connection piece of the grease tubing fouled the blade bracket. It has now been revised with a swivel type, that is smaller, moves slightly as you turn the steering wheel and is much easier to fit. My inborne modesty prevents me from telling who sourced out this item, modified the Wolf kit, fitted it with success and then informed Cain/Wolf, who incorporated it and even improved it a little more. It works very well. I know it is disputed because it allows you to just open the bonnet, grease and close it again - leaving the important checking under the car, especially if grease has got on to the brake discs. That is a matter of discipline. It is easy just to go down with a flashlight and check, much easier than doing the whole grease operation lying on the ground. I grease quite little but but also quite often, and when have checked there has never been grease on the discs or a threatening excess that I need to wipe off.
Robbie the Norseman 2004 V6 Roadster Sherwood green
Well done Robbie & Cain, mine was from the Nippleshop long time ago.
