0 members (), 254 guests, and 91 robots.
Topics49,847
Posts837,389
DazMog, The Impaler, tlchzj79
Page 4 of 19 1 2 3 4 5 6 18 19
Mine is quiet
With NVH And minéral oil 140
CasaLobo / 2014 / 1,400 / N / N/A / Steel / Y / Redline Shockproof
Great thread, thanks!
Chris99 Offline OP
Originally Posted By Rog G
Not very scientific but my belt tension.
In the middle of the belt there is 15mm of vertical movement whilst apply minimal force, alternatively I can twist the belt 40 degrees with some force. Prior to slackening the belt there was only 5mm maximum movement.
These results seem to pointing to the fact that temperature is causing problems with clearances and hence gear noise or insufficient preload of the pinion bearings, as the survey indicates the noise is worst when the bevel box is hot causing differential expansion between the aluminium housing and the pinion shaft. Not knowing the dimensions of the bevel box but If the bevel box is running at 120 deg C the pinion bearings are 50mm apart then the differential expansion cold to hot could be 0.06mm (0.0024 inches) which could be enough to upset the preload.
This still seems pretty tight - mine twists more like 90 degrees.
We can compare side by side on Sunday.
Red Leader drive
Gates don't say much about handling the belt apart from never twist it it damages the fibres
Chris99 Offline OP
Just checked my belt - 90 degree twist and 1 inch deflection.
Red Leader drive
Wow! that's loose. Checked mine at factory after it was first fitted and tensioned - max 30° twist - still the same after 700 miles.
2014 model, ab 8000 km, quiet when cold, whines when hot, original alu sprocket, no idea about the other stuff
M3W
From the Morgan PDI form
Outside the Car No 31
Drive belt tension (1/4 of a turn) & clear of the tyre.
Tim
2014 / 3500 / quiet up to 50mph, not too bad to 70 (get scared after that!) / original ally / no NVH
If more the outside from the belt will rub on the round frame pipe on the bottom.
This because when driving all slack will be on the lower part of the belt ( not pulling) this could be the reason why MMC tighten up the belt a bit more.
www.m3w-jungfrau-treffen.com
