1 members (JohnHarris), 234 guests, and 35 robots.
+8Rich 99
John V6 57
Topics49,911
Posts838,146
#365871 22/05/16 01:20 PM
vMog Offline OP
As mentioned earlier on this forum, I'm very happy with MMC who proceeded with sidescreen to windscreen sealing upgrade. I Really think it is an improvement every 4str owner should consider, since my sidescreeens are not being sucked out anymore.
There is something that's been keeping for a while though, as water still comes in from the windscreen/sidescreen/hood contact points : the inner vinyl (or mohair) end just doesn't feel right as it currently sits... If you have a look at attached photo, you can see that it keeps the sidescreen from touching the windscreen mount seal and actually creates a permanent mark on the sealing itself.
Here's my question to you: has anyone retrimmed that bit of vinyl/mohair to have the sidescreen stick to the windscreen mount?
Happy driving and kind regards,
Vladimir
vMog is a 2013 +4/ 4 seater, dark red with saddle brown trim, wooden dashboard and console.
vMog #365885 22/05/16 02:49 PM
What did they do? Is it just the addition of a rubber seal along the windscreen?
vMog #366012 23/05/16 06:15 AM
vMog Offline OP
Nop,
They added a U shaped seal to "frame" the sidescreen, hence keeping it into position.
Cheers
vMog #366021 23/05/16 06:55 AM
Dek Offline
I have been tempted to trim the mohair end, but haven't been game enough to do it yet! I would be interested to hear about the difference from anyone who has.
Derek
vMog #366050 23/05/16 08:33 AM
vMog Offline OP
I was told Allon White does the trim... but I couldn't get any feedback yet.
vMog #366052 23/05/16 08:46 AM
The channel rubber on the windscreen pillar is now standard and can be purchased from dealers for retrofit. It is a very good upgrade
Robbie
2021 Plus Four -- Helga
211-WX-1433
vMog #366077 23/05/16 11:14 AM
Any more pics of such?
Will
vMog #366094 23/05/16 12:35 PM
Found a topic on such on TalkMorgan
http://www.talkmorgan.com/ubbthreads.php/topics/160209/1
Order the required seal...
Will
vMog Offline OP
I've just seen a 4 str at Williams the other day and the rubber was apparently not on the package list...
vMog Offline OP
Will
Thanks Will,
That part is actually fine now.
What I mean is the part where windscreen/sidescreen/hood touch, in other words at the top of the pillars.
Cheers
