0 members (),
325
48
Topics49,844
Posts837,360
Posts: 1,338 |
Enjoy it, but "don't drive it like you stole it" be abit gentle on it, it's more of a cruiser.
Posts: 836 |
or drive it like you stole it and realize there will be more frequent maintenance.
Posts: 1,338 |
Posts: 541 |
If your belt is at one inch tension it's to lose. My dealer told me to set it at 10mm. You can pick up a tool at a Harley Davidson shop that will help you set the correct belt tension.
1998 +8 SS Sport tuned exhaust
2013 M3W Stage ll motor kit Cats removed
Posts: 1,625 Likes: 25
Posts: 1,625 Likes: 25 |
If your belt is at one inch tension it's to lose. My dealer told me to set it at 10mm. You can pick up a tool at a Harley Davidson shop that will help you set the correct belt tension. The factory set the belt tension with a device similar to this: http://www.gates.com/products/industrial...and-accessories
Posts: 1,815 Likes: 32
Posts: 1,815 Likes: 32 |
If your belt is at one inch tension it's to lose. My dealer told me to set it at 10mm. You can pick up a tool at a Harley Davidson shop that will help you set the correct belt tension. The factory set the belt tension with a device similar to this: http://www.gates.com/products/industrial...and-accessories Quote: First, enter belt mass constant, belt width and span length into meter using built-in keypad. Didn't see these in the M3W manual
If your belt is at one inch tension it's to lose. My dealer told me to set it at 10mm. You can pick up a tool at a Harley Davidson shop that will help you set the correct belt tension. The factory set the belt tension with a device similar to this: http://www.gates.com/products/industrial...and-accessories Quote: First, enter belt mass constant, belt width and span length into meter using built-in keypad. Didn't see these in the M3W manual The factory just set it to a resonant frequency, 45 to 50 Hz if I recall, using a device similar to the Gates product.
