6 members (Jens, +8Rich, jbk, Graham, G4FUJ, Deejay, MartO),
295
81
Topics49,850
Posts837,428
Posts: 625 |
Two solutions then, thanks Ian and John. Nice combo John with the Red Plus 2 and Morgan, we have a Red Elan S3 Coupè and a Morgan
Cheers John 2011 4/4 - "Elrond" 2007 Elfin C3 Clubman - “Gimli”
Posts: 614 Likes: 22
Posts: 614 Likes: 22 |
Nice combo John with the Red Plus 2 and Morgan, we have a Red Elan S3 Coupè and a Morgan Yes well,you do need to have one car with working suspension.  Still your combo is not too bad, the FHC is a very pure shape I think. Cheers John
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
Dimensions....................
Length is 2 feet or 610mm. Minimum width is 20mm. This is not critical. The metal runners are 20mm wide so 20mm spacers are very tidy. I'm using slightly wider spacers for the new car. The hole for the protruding nut needs to be 15mm or 16mm. The holes for the fixing bolts can be 10mm if you can achieve perfect alignment, but 13mm holes will allow some wriggle room.
Hole centres from the front are 13mm; 96mm; 185mm for the nut hole; 508mm.
Height? I'm now using 10mm thickness. You can use up to 30mm but at that there is not much thigh space under the steering wheel.
In my Roadster with factory wood, and the higher dash, the spacers are 30mm at the front and about 20mm at the rear - so a front to rear taper. Minor adjustments can be made with washers and as noted above, you can just use washers under the runners on each fastener to lift the protruding nut off the floor.
Longer bolts may be necessary.
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
Thanks Dave. What would be the minimum thickness to do the trick. I don't want to raise the seats more than absolutely necessary. Looking at the photo I am guessing that 8mm would be about the minimum.
8 mm should just do it Peter. If necessary you could grind or file the protruding part of the bolt level with the nut.
