0 members (),
230
40
Topics49,904
Posts838,083
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
Plus 4 engine mountings can squeak and the sound travels. Check by rocking the engine. If the bonnet tapes dry out they will squeak. And a creak I had on Bumble at the front nearside corner of the bulkhead turned out to be one of the tacks holding the bonnet tape to the bulkhead. A tiny amount of up and down movement generated a huge creak. That took some finding.
Posts: 1,707 Likes: 36
Posts: 1,707 Likes: 36 |
Plus 4 engine mountings can squeak and the sound travels. My nearside engine mount squeaks when the car is warm and sat ticking over on my 10° slopping drive outside the garage. Sounds hideous sometimes. Fortunately its ok on the level
Roger 2011 Plus 4
Posts: 37,481 Likes: 989
Posts: 37,481 Likes: 989 |
Castor oil is good for that type of problem I believe.
Posts: 2,433 Likes: 17
Posts: 2,433 Likes: 17 |
I use Waxoyl on springs, works well and has good creeping properties to get in between the leaves.
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 407 |
I too have squeaky leaf springs. I have spotted WD40 motorbike chain lube at Halfords which it says is o/x/y whatever that is. Anyone any idea whether this is acceptable for leaf springs? Cheers
Stuart
Rich Maroon and Royal Ivory (ish) +4
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
Any thing is acceptable for leaf springs even a nice bit of beef dripping.
What ever lube you use it just needs to get between the contact points an lube them. They could do with a leaf lube to save the rolling around on the garage floor.
Posts: 4,655 Likes: 124
Posts: 4,655 Likes: 124 |
My ear phones work a treat!
2021 Lapis Blue Plus 6  You know it makes sense!  2016 Carmine Red 991.2 C4S
Posts: 4,896 |
What ever lube you use it just needs to get between the contact points an lube them. They could do with a leaf lube to save the rolling around on the garage floor. Final fix, remove leaf springs, and replace with new high grade ones, before fitting new ones take them apart and carefully file the rub points for each leaf so there are no catch points soak in in oil bath for 24 hours, reassemble packing with a hydrophobic grease ( i would recommend Lucas Red n Tacky), then carefully wrap in leaf spring tape and then coat with grease based sealant to protect and refit. Then forget for 10 years. (this is the Rolls Royce approach)
Adrian
