2 members (MOGDave, Daniel Craig), 259 guests, and 31 robots.
+8Rich 94
John V6 49
Posts837,991
rockabilly john
#370590 13/06/16 08:45 PM
I was hoping to get some thoughts on this rust on the exhaust of my 2014 M3W.
I have treated it with ACF50 a few times now, including leaving it for a few days without use to keep it on the metal for longer before burn-off.
Has anyone else experienced this development? Any ideas on how to combat it? Worrisome?
Thanks.
CasaLobo #370597 13/06/16 09:24 PM
kwb Offline
Ouch! With that amount of rust I would be worried too - must check my '14 M3W tomorrow!
Karl
Life is hard in the mountains
2009 silver +4, 2013 red C4P, 2014 yellow M3W gone to a new owner
kwb #370599 13/06/16 09:47 PM
End caps of the flexible part are mild steel. I suggest complaining to the dealer as I'm pretty sure they're not supposed to be.
CasaLobo #370601 13/06/16 09:55 PM
My thoughts also, hopefully it's still in warranty.
Martin (Deano)
deano #370610 13/06/16 10:44 PM
Thanks, guys. I've reached out to the dealer, but frankly at over 1,000 miles away, I may need to rely on a less than ideal solution (thanks for the high-heat paint suggestion). I'll see what the dealer says first though.
My only concern is that with that much rust, high-heat paint may only serve a band-aid and I could end up with some catastrophic failure of the end cap...
CasaLobo #370635 14/06/16 07:50 AM
The rusted part appears to be a galvanised mild steel collar allowing it to be crimped onto the flexy and shrunk onto the stainless pipe.
The issue seems to be the poor galvanising.
CasaLobo #370638 14/06/16 08:01 AM
It's probably easier just to replace them with stainless steel equivalents, they aren't very expensive, around £25-£30 in the UK, depending on size.
Any local exhaust place or general fabricators would be able to weld them in place if you didn't fancy using clamps.
CasaLobo #370646 14/06/16 08:12 AM
Or treat with Rust cure - then hi temp paint??
Neil
NeilL #370710 14/06/16 12:19 PM
Most flex joints like these that I've looked at on other projects are listed as stainless steel, but still have aluminized steel on the ends. Over time these can still rust.
There may be some specialty shops that offer complete stainless flex joints, but I haven't found any yet.
Dan
