1 members (mph), 251 guests, and 33 robots.
+8Rich 99
John V6 57
Topics49,911
Posts838,148
Page 5 of 5 1 2 3 4 5
Originally Posted By flyfisher
Harald,
How does the air suspension setup work, it sounds ideal.. Would it be expensive to fit?
The air suspension retains the original leaf springs and the original Bilstein dampers. Two additional air suspension dampers are fitted along with a compressor. A switch under the dashboard allows the driver to release the air pressure to lower the car or increase it to gain ground clearance. Air suspension is progressive so it acts as a soft bump stop in addition to controlling ground clearance. It would be possible to add a pressure gauge, but so far I adjust the pressure depending on the number of passengers and the road conditions. The cost in 2014 was £2800 of which £1100 was for the parts. This is not cheap, but I am very happy with the result.
Harald
Harald
Rog Offline
Originally Posted By John V6
Roger,
I would be interested in a 2 seater set if the price is right
No problem John. If they do come to fruition I don’t think they will amount to very much.
Roger
Roger thanks I will try filling the piggy bank then!!
