1 members (GLLOQ), 209 guests, and 32 robots.
+8Rich 96
John V6 52
Topics49,897
Posts838,018
I believe its approx £650 unfitted , sorry dont know the part number
Thank you.
I should have some backlash in it, both the ones Ive had have been about the same
Did a + 7 hours trip today and this F***ing bevel box noise makes us crazy.
It spoils a great part of the pleasure.
Please, please MMC come with a solution !!
www.m3w-jungfrau-treffen.com
If you look for my original post it will show what I did for a rebuild. I used Timken bearings and races for my rebuild. I recommend Lucas oil stabilizer for the box. You can run it at 100% but I thin it a little with 140W Lucas synthetic gear oil, 10%. After you install new bearings change out the oil in 1500 miles and check pinion preload without the seal installed. You want no less than 180 inch pounds with new bearings. If you backlash is no good you have to fabricate your own pinion shims.
"Know the black and white before you walk in the gray"
Remove interior and trunk panel.
I have just called Morgan, and pressed 2 for service and warranty, it rang through to leave a message, so I did. Do I need a part number for a recon, if I manage to get hold of them?
Believe me , they know what a recon bevel box is, regardless of part number !!! You shouldnt have to know their part numbers to order.
I suggest you keep ringing until you speak to a human.
I have found it easier to get through to the parts department.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
I have just sent an email to Mark Evans, as someone suggested. Fingers crossed.
