0 members (), 323 guests, and 27 robots.
+8Rich 95
John V6 52
Topics49,897
Posts838,017
#374122 30/06/16 07:42 PM
Pulled roll bars today because they were rubbing the body, the creaking noise behind my head had been going on long enough. Besides rubbing the body I found that the inner chassis tubes were FULL of WATER and the roll bars themselves are thinner than exhaust pipe. So, drilled some drain holes at the base of the inner bar mounts, drum sanded more clearance in the body and will be getting with a race chassis shop to make some REAL roll bars this winter. Pictures attached.
"Know the black and white before you walk in the gray"
Get some ACF50 Down there.so much for the tubes being coated inside and out!
kirkusblog.com
1952 Ford 8N
Acf 50 will help but where steel and aluminium come into wet contact you will get a galvanic corrosion. The hoops do rock but the hole must be made large enough that it cannot touch, the rubber gets bitten through and the protection is gone. Aluminium is a bugger for corrosion. Mine has gone about 10mm round each hoop in the body
From the pictures it looks like the water went UP the rollbar ? confused
Something I have never considered doh
Just gets better and better, doesn't it innocent
thumbs cheers
2013 M3W # 793
'Mosquito'
