Topics49,870
Posts837,669
Posts: 2,310 Likes: 5
Posts: 2,310 Likes: 5 |
So I have the lights mounted, most of the wiring and relay in place...question Team:
What are best options to pick up high beam connection ?
from headlight end or from fuse box location.
I will probably mount relay in fuse box/ecu box to protect from water/dirt .
Thanks
Posts: 6,723 Likes: 2
Posts: 6,723 Likes: 2 |
Rules, Kev..! Pics or you're making it up, chap.. I'd plump for a pickup from the warm, dry & accessible fusebox end if poss..
Steve Captain Morgan ....he no lie !!!!!
Saw these today at Blenheim. With a TM sticker on the screen, my guess it's someone on here, but I wonder what the spots are mounted on?
Posts: 27,816 Likes: 749
Posts: 27,816 Likes: 749 |
Yes I saw those from a distance & did wonder
Posts: 2,272 Likes: 7
Posts: 2,272 Likes: 7 |
Guys
While you are doing any re-wiring I would spend time putting in a couple of relays , one each for high and low beams, especially if you are adding spots to the high beam circuit.
This does 2 things , it takes most of the electrical loading off the switch, and preserves the contacts, and it ensures that you have full voltage at the lights and not way back down the wiring loom.
Posts: 39 |
Judging by the comment on the Blenheim thread, this green 4/4 must be PhilRoyle's car. Cheers
Posts: 4,612 Likes: 15
Posts: 4,612 Likes: 15 |
This is what I did. Wise words. Guys
Posts: 145 Likes: 1
Posts: 145 Likes: 1 |
And the power should come from the alternator post !
