9 members (2949olivier, MJF, BLUE+4, deano, paulmog, Ncik P, GrumpyPa, jbk, stefan s), 205 guests, and 95 robots.
+8Rich 78
Topics49,871
Posts837,677
Rudolf
#374763 03/07/16 07:36 PM
KEVFITZ Offline OP
So I have the lights mounted, most of the wiring and relay in place...question Team:
What are best options to pick up high beam connection ?
from headlight end or from fuse box location.
I will probably mount relay in fuse box/ecu box to protect from water/dirt .
Thanks
SBM Offline
Rules, Kev..! Pics or you're making it up, chap..
I'd plump for a pickup from the warm, dry & accessible fusebox end if poss..
thumbs
KEVFITZ Offline OP
Captain Morgan ....he no lie !!!!!
SBM Offline
grin2
SBM Offline
Saw these today at Blenheim. With a TM sticker on the screen, my guess it's someone on here, but I wonder what the spots are mounted on?
Yes I saw those from a distance & did wonder
Guys
While you are doing any re-wiring I would spend time putting in a couple of relays , one each for high and low beams, especially if you are adding spots to the high beam circuit.
This does 2 things , it takes most of the electrical loading off the switch, and preserves the contacts, and it ensures that you have full voltage at the lights and not way back down the wiring loom.
Andy G
1999 +8 , Indigo Blue.
Judging by the comment on the Blenheim thread, this green 4/4 must be PhilRoyle's car. Cheers
This is what I did. Wise words.
Originally Posted By MOG 615
Guys
And the power should come from the alternator post !
