3 members (planenut, AlyMatt, Paul F), 266 guests, and 43 robots.
John V6 79
+8Rich 70
DaveW 67
9,203 Registered Users
Supermax sprocket
Morgan 3 Wheeler song
by Dutch - 21/07/25 12:31 AM
by Oskar - 20/07/25 04:13 PM
Goggle eyed
by Roady - 19/07/25 06:16 PM
by t50 - 19/07/25 12:07 PM
Lions Tour
by OZ 4/4 - 19/07/25 11:55 AM
Morgan rebuild on Facebook
by TBM - 19/07/25 10:50 AM
Topics48,337
Posts812,917
Members9,203
toitoine
Georgie Offline OP
Have just got my car back from the local garage (not a Morgan workshop) who have fitted a sports exhaust for me. When I picked the car up this afternoon the fan was running but the mechanic had been running the engine to check for exhaust leaks etc. however on arriving home, just a short trip the fan continued running. I have removed the fuse. Any ideas?
David
2001 4/4 Zetec silvertop.
David
The fan will continue to run until engine temperature has dropped and is perfectly normal, it's controlled by the ECU.
Mark Evans
Originally Posted By Mark Evans
Mark Evans
A Car is Born?
Best Regards
Lang may yer lum reek
Georgie Offline OP
David
Mark Evans
Thank Mark, the engine was cool to the touch, I am thinking it may be the Otter Switch or a short?
No not a car is born
I'm much more infamous than that (LOL) smile .
Mark Evans
Aero Racing Manager
Morgan Motor Company
Mark knows his stuff but as the block is cool to touch and the fan is still running could I suggest you have a look at the fan control relay. Not common but not unknown for a relay to have its contacts welded shut. If your car has a fan switch in the radiator might be worth pulling the wires off and if you have an Ohm meter checking to see if it's closed circuit, it should be open circuit when cold/cool.
BR
Colin
BR Colin
On a 2005 Roadster, the fan quit. I could not figure out what the problem was. So I installed a Flexolite Temp. Switch. I put the probe into the upper (probably should have been lower) hose and connected Wires. It is hard wired (no switch). Seems to work OK. Temp is adjustable. Just by-passed the existing wiring plugs etc.
Button
Seattle
Button
Whilst I hate to tell the factory they're wrong about something...
The ECU didn't control the fan until the "Black Top" Zetec or Focus engine was fitted in late 2001/early 2002
Chances are it's the otter switch (bottom right of the radiator) throwing a wobbler or as Colin pointed out, the relay may have fused in in its "on" position
Simon @ SiFab.co.uk
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
I've had a Kenlowe (yes, aftermarket but the principle is similar) "relay" stick in the on position... smile
'09 Gen2 MINI Cooper ragtop
Georgie Offline OP
Thanks Guys, I have a Escort 1997 silvertop (I found this out by the number on the timing belt) will check the relay if I knew where it's located? I will also check the otter switch circuit for open.
David
