0 members (), 320 guests, and 32 robots.
+8Rich 97
Luddite 54
Topics49,904
Posts838,088
#37592 19/11/09 05:18 PM
Ivo Offline OP
TM Photographer of 2011
Hi
This is the result of a three hour tinker session:
I like it very much. In my opinion, this is the position where the number plate has to be.
For comparison:
Sunny Greetings,
Ivo
sunny
1998 +8 (permanently out of service frown )
Ivo #37594 19/11/09 05:26 PM
A very neat job. Well done.
Goodwood Drifter
Goodwood Drifter
looking forward to see that IRL
If I start modding,
read: after body-work-repair
I would:
- change licence-plates like you
- remove top-wing-lights
- remove rear reflectors (place 4/4-sports-reflectors)
Steven
now: +fourLM62
Ivo #37598 19/11/09 05:41 PM
Green & Grown Up
Green & Grown Up
I totally agree Ivo. I need to get to this some time soon,
1560 #37600 19/11/09 05:54 PM
Ivo Offline OP
will be my pleasure smile
Personally, I like those. But like anything else, it's a matter of taste
Yeah, they are really cool. Unfortunately, after removal of the originals, there is a paint job to be done.
Sunny Greetings,
Ivo
sunny
Ivo,
Any chance of a step by step guide -- I totally agree that this is much better than the factory position.
Cheers!
Robbie
2021 Plus Four -- Helga
211-WX-1433
Ivo Offline OP
I also thought, this job would be a nice "number 7" on your to-do list wink
sunny
Ivo #37606 19/11/09 07:40 PM
Very nice job Ivo! wink
THIS looks like it should be! Got a confirmation that my Sport went into production today, laugh and one of my first modifications will the front and rear plate fixing.
My first thought was rotating the original fixture by 180 degrees and attaching it from below – Would you think this is possible?
Cheers
Sven
Ivo Offline OP
Originally Posted By Pistonhead
(...) My first thought was rotating the original fixture by 180 degrees and attaching it from below – Would you think this is possible?
Cheers
Sven
I don't think so. The upper number plate holder and the lower part, where the fog- and backup light are mounted, is one piece.
It's made from plastic, so it was very easy, to cut the plate holder of. After having done that, I attached the number plate with a stainless steel angle. As mentioned before "tinker" wink
I'll take some close-up pictures camera and post them soon.
Sunny greetings,
Ivo
sunny
Ivo #37612 19/11/09 10:04 PM
Exactly my plan! One of the guys with a +8 LM62 did this very job and looked excellent (he has a smaller Swiss Number pLate too!).
I too would be interested in how you removed the rear plate. On investigation on mine it appears that I have to remove the brackets that hold the overriders. As they are mounted through a hole in the rear plate that is not big enough to slide the plate over the brackets with the overriders removed. So the next challenge was to locate how these brackets are attached to the chassis. I saw two bolts but need to see how easy they are to remove and how easy to slide the brackets out to drop the rear plate. I then plan to fabricate a new panel as do not want to destroy the original. Similar to the front number plate 'box' on my car the rear panel is aluminium and harder to cut than the later ones. It is quite strange that one of the other LM62 guys tells me his rear plate is actually seperate and it is possible to remove it. I find it strange as all the LM62 cars were built at the same time with common components.....the mystery of Morgan!
Keith
