Topics49,901
Posts838,041
Posts: 834 Likes: 28
Posts: 834 Likes: 28 |
Hi StEve - I bought the 1991 4/4 18000 miles st890. Expect delivery next week after king pins tyres and service . Any comment - suppose you don't know the car do you ? Car looks to be in good condition from the pics Mikey, does not seem to have a reversing light though?
1993 T16 +4 Lancia Blue.
Posts: 898 |
Although I certainly agree that getting mains power to the garage is something that should be highly recommended, I think you may be being a bit optimistic here Eddie - have you seen the price of SWA lately.
Yes and SWA is not that expensive, wired up lots of friends garages and sheds. Yes you do have to pay for the cable.I always wire to the 17th edition of the IEE regulations which usually adds say £10 to the SWA cost as you need to increase the conductor size of the SWA to get the lighting voltage drop below 3%. It's not a game changer If as in my case the electrics were up to date in the house and I had a spare "way" not a problem when I did my new workshop garage. With all due respect if the electrics in my house were out of date, I would do what I did when we moved in to the house 20 or so years ago. I updated the electrics to modern rcb and earth leakage protection and I replaced cables that were old or over capacity in the house. That's not a garage wiring cost it is the cost of home safety. Remember also that work like this has to be certified and inspected, and if it involves replacing the consumer unit - to add a new RCD/MCB for example - then the whole house has to be inspected, and any deficiencies must be fixed before work can be done.
We found this out when we had security lighting installed, I nearly had a heart attack when the electrician told us he had to test the wiring in the house first. Not normally a problem, but in our ancient cottage, that had been rewired more than 40 years previously, it was a different matter. Fortunately the wiring passed, so we were ok.
Yes I did get my house electics proffessionally tested and I did not consider that anything other than what you need to get done every say 5 to 10 years or so. Just like I get a roofer round every few years to go up on the roof and check the slates and flashings. Sorry but being able to mess about in a bright warm garage is just great but yes insulation, electics and other stuff has to be paid for. eddie
Posts: 12,265 Likes: 321
Posts: 12,265 Likes: 321 |
[quote]
Yes and SWA is not that expensive, wired up lots of friends garages and sheds. Yes you do have to pay for the cable.I always wire to the 17th edition of the IEE regulations which usually adds say £10 to the SWA cost as you need to increase the conductor size of the SWA to get the lighting voltage drop below 3%. It's not a game changer <snip>
eddie Fair enough, I certainly agree with you about having a decent electricity supply to the garage, it's just that having 50m of 6mm SWA laid to our garage ended up costing us way more than £200, and that's with our electrician doing the job at mate's rates. Well worth doing, though.
Posts: 47 |
I have more of a problem - in that the garage is about 50mts other side of the lane we live in. There is a an electric pole quite near the garage and I fear the answer will be a new supply just to the garage with its own meter !!
when all is said and done - there is more said than done .
Posts: 766 |
I've had two Morgans over 5 years and have never placed my battery on charge, only once did they let me down and that was after 5 weeks of non use in a cold January/February. The answer is to use it regularly, all year round, at least weekly and go for a decent drive to recharge....a Morgan is for driving after all.
Tuftie66 2008 Claret Red +4 Sports 2016 Mazda CX-3, Sport AWD.
Posts: 1,948 |
I have more of a problem - in that the garage is about 50mts other side of the lane we live in. There is a an electric pole quite near the garage and I fear the answer will be a new supply just to the garage with its own meter !! See how you get on. My 4/4 will hold charge for months without use  and start first time. Whereas my Aero struggles after 4 days without its CTEK life support. If you can use the car as regularly as many are suggesting, you might not need to spend the money putting armoured cable to your garage. Buy one of the portable capacitative jump-starters instead, then you have a Plan B.
Stuart "There's no skill substitute like cubic inches."
Posts: 681 |
That looks a nice car with very low mileage - congratulations! A shame you can only use it at weekends. And a pity, too, that you don't have power because I also have a CTEK which I have been using since 2010. If and when you can park near a power source, they really do give good peace of mind.
I don't know your car, but I do know Allon White well and can say that they never fail to impress me.
Posts: 27,839 Likes: 764
Posts: 27,839 Likes: 764 |
Steve, I would agree they are a good dealer
