Topics49,899
Posts838,024
Posts: 123 Likes: 6
Posts: 123 Likes: 6 |
While trying to lubricate the kingpins, it seems one of the grease nipples on the front suspension of my 1975 4/4 is blocked. Does anyone on here know the exact size of these please? From what I can work out they may be 1/4 x 28 UNF. I currently have a 90 degree angle, which may not be the best for flow? Any recommendations please for regular grease nipples. I appreciate I could buy a remote conversion kit or even a newer Morgan, but would prefer responses to size of grease nipples required. Many thanks!
Posts: 12,265 Likes: 321
Posts: 12,265 Likes: 321 |
They are 1/8" BSP. I find a 45 degree angle works best. You can get them here
Posts: 123 Likes: 6
That's great Hamwich.
Thank you for your help and such a quick response.
Off to order them now!
Cheers.
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
The other thing to try is to unscrew the grease nipple and leave in degreaser for a bit and then try it on the bench and refit if working.
Richard 1976 4/4 4 Seater
Posts: 123 Likes: 6
If anyone else has the same issue, the 1/8 BSF nipples arrived, they are much larger, than those currently fitted
The correct size for the stub axle grease point on a standard 1970's 4/4 is in fact 1/4 UNF as I originally thought.
I am now off in search of those!
I am now off in search of those! Oops, sorry about that! I wonder when they changed - they are certainly 1/8 BSP on my 1986 car (you did get BSP not BSF, didn't you?) You can get 1/4" UNF nipples from Vintage Motor Spares too, as per my original link.
Posts: 1,149 Likes: 19
Posts: 1,149 Likes: 19 |
Do we know what size the nipples are on the drive shaft between the gear box and rear diff.
Also what is the size on the thrust clutch on the earlier cars located in footwell
and is the same grease nipples on the footpedals spindle?
Morgans 1934 MX, 1947 Series 1, 1956 +4 TR4, 2000 +4 T16 Triumph Herald 1969 13/60 Morris 1970
Posts: 93 |
So, here is my question. The newer cars have the grease nipples. The older cars have an oiler system. Which is better? I am at the point of reinstalling the oiler system or replacing it with grease nipples. Need some advice.
Posts: 1 |
Can anyone please clarify exactly which size thread are the front suspension lower grease nipples on a 1971 4/4 4 seater? So far, it seems it's been suggested that they are: 1/8" BSP, 1/4" UNF OR 1/4" BSF. Can anyone say for sure which is correct, before I start the next quest, which is where to source them locally, in West Yorkshire. Many thanks
Posts: 834 Likes: 28
Posts: 834 Likes: 28 |
I would guess if a car has an oiler system that is what it is meant to have, i am sure i have read somewhere that the kingpins on oiler cars where not designed to be greased from the top. On the basis that modern oils are thinner, I have fitted lathe oiler cups to gravity feed clean oil instead of squirting an unknown quantity of used oil from from the engine. Not very technical as it requires personal judgement, but little and often seems to keep the pins oiled without it washing out the grease or dripping out, works for me but may not suit everybody. As for grease nipples i would order two of each as they are cheap, the ones you have over will make a nice pair of earrings for the other half.
1993 T16 +4 Lancia Blue.
