1 members (SailingTom2),
241
Topics49,897
Posts838,018
Posts: 1,947 |
As HJP says petrol on the stock aero screens can damage them. My L/H screen was affected & cracked. I've now fitted a Fairbourne screen.
Tim
Posts: 1,664 |
Yes, one of my windscreens is now pitted in an area from the fuel spray.
Charlie, Former Editor Morgan Owners Group - Great Lakes
Posts: 1,338 |
[url=[URL=http://s1349.photobucket.com/user/Q8morgan/media/image_zpsombpj1hl.jpeg.html]  [/url]][/url] Changing the clamps. Better safe than sorry.even though I didn't have a problem.
Posts: 5,017 Likes: 3
Posts: 5,017 Likes: 3 |
Thank you for the picture! I was a little bit lost searching for the tubes (city cooling kit on) Now it is easy...
Posts: 1,338 |
[url=[URL=http://s1349.photobucket.com/user/Q8morgan/media/image_zpsey8aouqv.jpeg.html]  [/url]][/url] Its a bit of a hassle to remove the factory clamps.
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
It is a good idea to replace the factory fitted crimped on fuel hose clips as they do have a history of leaking around the injectors. In the picture you have posted, I may be wrong but it looks like you have replaced them with Jubilee type clips rather than proper fuel hose clips, like these: http://www.carbuildersolutions.com/uk/stainless-steel-fuel-hose-clips-13-15mmThere is a difference, Jubilee clips do not give an even 360 degree pressure and can allow leaks.
Posts: 1,338 |
I will give it a try during winter..its boiling hot here in kuwait. But i started it for a few minutes & there aren't any leaks..thats what i use on all my hot rods & they work just fine with me..i will look into your link
Posts: 1,947 |
Q8 did you change the two clamps at the other end of the hoses down behind the engine? I agree with planenut & used proper fuel hose clips.
Tim
Posts: 1,562 |
I am looking to get some clips to exchange mine over to fuel hose clips "just in case". I think I need 4 - 2 for the crossover pipe between the injectors and 2 for the feed pipe - is that right ? Thanks
4 hose clips on the engine, as detailed and 2 more down the back of the engine at the other end of the rubber hoses. These are not replaced by the factory when they do the modification and don't seem to have a problem with leaking like the engine mounted ones do. Possibly replacement of them isn't required?
