1 members (+8Rich), 279 guests, and 42 robots.
+8Rich 99
John V6 57
Topics49,911
Posts838,149
Georgetoad, woolfie
docdav Offline OP
Helle overyone.
I am new in the forum here.
Just bought a 4/4 from 1984.
The instrument light seems very weak. Tried to turn the reostat all the way up but alas?
And where is the battery???
Any good ideas?
Kind regards.
Michael
In my 1991 4/4 the battery is under the rear parcel shelf wooden board is held by clips.
But my instrument lights are not that bright .
Somebody will be on here soon to give advice
Andrew
Ray Offline
Welcome from a foggy west Wales.The dashboard lights on my +8 are very dim, its normal on trad morgans.
Probably best to replace instrument lights with LED versions if they really are too dim.
Battery, as someone else has posted is ahead of the rear axle under the parcel shelf.
Welcome to the forum! smile Have fun in your new car thumbs
Had a shock when I first saw your name - "Doc Dave" was our motorsport medic at Prescott Hill Climb for a good number of years until he retired. Then I realised no "e" on the end and you are in Denmark! smile
Welcome, does the dimmer actually do anything? Might be worth bypassing it to see if the lights are getting 'full juice' and if the lights improve. They aren't very bright from standard so don't expect them to be anything like modern led's.
2008 4/4 1.8 Duratec
If some lights are better than others, check their in their housing (I think in your model judging my the photos they just push in. They might have come loose.
Otherwise as Graham suggests change to LED.
docdav Offline OP
All are poor, seriously considering LED.
My instrument lamps are fine.
The Bulbs could be past their sell by date and smutted up on the inside of the glass. Or even the wrong bulbs.
Corrosion on the instrument case metal eating some of the juice - take some scotchbrite to it.
Wiring seen better days
Pot chucking out to low a voltage.
What is the volts on the ciggy lighter with engine running should be about 14.5
Mark - No Longer driving
1984 - probably hasn't got one Mark! smile
docdav Offline OP
Oh yes it has one, the regular instrument reads 12.8 v
