7 members (TeddyAds, nick w, RobC, JMcL, TalkMorgan, RedThree, Liam1961), 296 guests, and 92 robots.
Sagging Hood
Topics49,859
Posts837,469
Page 3 of 3 1 2 3
SteveT Offline OP
Originally Posted By elaine2010uk
Hi
We sell Remote Greasing Kits for Morgans.. smile
See attached.
Kind Regards
Elaine
yes and very good they are too but the instructions need some work! They make no mention of several tricky aspects that only become apparent when trying to fit them!
E
E
Hi SteveT
Thank you for your input.
The instructions were provided to us by a Morgan Owner.
If you would like them more detailed, please let me now, or forward detailed instructions & I will update it.
Thank you
Elaine Farnworth
Sales Engineer
email: elaine.f@hle.co.uk
Elaine,
If Steve's instructions were as good as mine, it's called sarcasm. There were none.
Couple of other points, no nuts provided for the screws to hold the blocks and are we really supposed to screw a M6 stud into the 1/4 UNF hole in the stub axle? Not for me anyway.
Cheers
Just fitted my kit today. I had to loosen both bottom nuts for the dampers to enable my to remove the grease nipple and replace with the new elbow fittings.
I found that I needed to use some copper washers to pack out the elbow fittings to secure them in the right planes.
Warm the tubes in hot water to make them a bit more flexible.
Also, I found it easier to setup the tubes and fittings to the blocks before fixing the block to the car and then connect the tubes to the kingpin fittings.
Ian
SteveT Offline OP
Good job Ian! Bit fiddly isn't it.. Where did you fit the blocks in the end?
I fitted them in the engine compartment in the end. I may have to move them down an inch as they are getting in the way of the bonnet stays. The result of a change of plan! Grrr!
Ian
I drill the KP to the space between the bushes with a long 3/16" drill than cross drill with a 1/8" drill so the grease will flow. If You are using Hardened Chrome with Induction Hardened rod, drilling the cross hole needs a special procedure. I use non induction Hardened rod when I drill this grease galley. 6 Pak of Beer job. Put zerk on top and grease without crawling on your belly.
Button
Page 3 of 3 1 2 3
