A few people may remember a while back I was trying to source a Librands short shift for my S1 Aero 8 with no success, if I recall I wasn't the only one.. well if you are interested in obtaining one read on!
Firstly a bit of background on the kit - it is made up of a new gear lever shaft from an old (E46 I think) M3, some bearings, shims, washers a new gear knob and some machining to these items.
Now the problem was the gear lever shaft, BMW said it was discontinued and therefore the kit was unable to be supplied.
I am a bit of a perfectionist and didn't want to just cut down the shaft if there was a better option which would reduce the throw via the bearings as well as on the lever length - so I have spent a lot of time digging!
I spoke to Librands (Phil) and he said it had been many many years since they supplied one, he was unable to source the shafts - bearings were no problem.
I didn't really fancy the hassle of finding a used shaft so I obtained the part number of the discontinued part from Phil and went to BMW. After a bit of searching on their system the helpful parts chap located a supersession of the lever - he wouldn't guarantee it would fit and it was a special order non-refundable part from Germany - but I took the approx £100 plunge and ordered it anyway!
Long story short it arrived and I sent it to Phil along with my choice of gear knob from Richbrook, he has confirmed it was correct and as such I have a fully fledged short shifter kit now in the post to me! The first in about 10 years.
I will dig out the number of the shaft later for anyone that is interested, as if you supply the shaft Phil is happy to produce a short shifter kit for the S1 again.
Approximate prices:
Shaft £100
Knob £40
Labour/bearings £100.
The benefit of this kit is it doesn't modify any existing parts, so you can put it back to standard if you wish. It also provides a quicker/shorter shift with more precise action than just cutting down the shaft itself.
Hope that helps someone, and I will post up some pictures when I get around to having it fitted.
Regards,
Nick
