10 members (dakri, IcePack, lez, JoeSpeetjens, MartinB60, JohnHarris, HJP, Plus Four Guy, TBM, Mogdavid), 285 guests, and 46 robots.
+8Rich 91
Luddite 50
Posts837,973
Page 2 of 4 1 2 3 4
JVS Offline
when using a hole saw to open up the baffles, I've been told to use a very slow turning speed of the hole saw to cut open the baffles. if you do it at a fast speed the baffle metal hardens and the hole saw dulls up very fast.
JV Sclafani
Boca Raton, FL
'13 M3W Metallic Orange Pearl
128CI Steered by Empire - Riding on Ohlins
Has anyone removed just the front baffles? If so, is the car too noisy now?
Thanks
Presume it's a cut and reweld job ?
Does one remove the baffles or just cut a hole in them?
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
You remove them with a hole saw.
No cut and rewelding involved...
I took mine out 2 years ago, I used a 38mm hole saw in a cordless drill with plenty of lube on the cutter.
Did you remove all the baffles?
How does the car sound now?
Having heard Mol & Squirrel's DIY cat-less/baffle-less set up and my stage 1 kit next to each other, they are very similar in sound but the stage 1 kit has deeper bass in the exhaust note. They both sound great IMO; I prefer the Stage 1 exhaust note but the hole saw method is much cheaper and you get to retain your original heat shields without the added cost of the new brackets, heat-shields and having to drill another hold in the side of the Mog.
Charlie, Former Editor
andre, Gets people's attention. I've driven past the cops and thet don't seem to care.
Removed the exhaust and took a pic of the front baffle....now I understand why the headers are glowing!!!!
Well.... Thats a bit restrictive!!!
kirkusblog.com
1952 Ford 8N
Page 2 of 4 1 2 3 4
