2 members (bmgermany, Taffmog),
331
42
Posts837,990
Posts: 462 |
when using a hole saw to open up the baffles, I've been told to use a very slow turning speed of the hole saw to cut open the baffles. if you do it at a fast speed the baffle metal hardens and the hole saw dulls up very fast.
JV Sclafani Boca Raton, FL '13 M3W Metallic Orange Pearl 128CI Steered by Empire - Riding on Ohlins
Posts: 23 |
Has anyone removed just the front baffles? If so, is the car too noisy now?
Thanks
Posts: 2,433 Likes: 17
Posts: 2,433 Likes: 17 |
Presume it's a cut and reweld job ? Does one remove the baffles or just cut a hole in them?
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 23 |
You remove them with a hole saw.
No cut and rewelding involved...
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
I took mine out 2 years ago, I used a 38mm hole saw in a cordless drill with plenty of lube on the cutter.
Posts: 23 |
Did you remove all the baffles? How does the car sound now?
Posts: 1,664 |
Did you remove all the baffles? How does the car sound now? Having heard Mol & Squirrel's DIY cat-less/baffle-less set up and my stage 1 kit next to each other, they are very similar in sound but the stage 1 kit has deeper bass in the exhaust note. They both sound great IMO; I prefer the Stage 1 exhaust note but the hole saw method is much cheaper and you get to retain your original heat shields without the added cost of the new brackets, heat-shields and having to drill another hold in the side of the Mog.
Charlie, Former Editor Morgan Owners Group - Great Lakes
Posts: 582 |
andre, Gets people's attention. I've driven past the cops and thet don't seem to care.
Posts: 23 |
Removed the exhaust and took a pic of the front baffle....now I understand why the headers are glowing!!!!
Posts: 2,539 |
Removed the exhaust and took a pic of the front baffle....now I understand why the headers are glowing!!!! Well.... Thats a bit restrictive!!!
