5 members (MJF, Adam12, 1560, TBM, Topline123), 328 guests, and 43 robots.
+8Rich 64
Adam12 62
John V6 58
9,215 Registered Users
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Tom Lehrer RIP
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,362
Posts813,325
Members9,215
Page 2 of 5 1 2 3 4 5
E
E
When they ship cars do they automatically disconnect the battery?? Check with them, if so as spanner juggler mentions the ecu/immobiliser may have "lost" its memory,
Ian
2017 Mercedes Benz SLC 200 AMG.
2019 Mercedes Benz GLA 200 AMG
Now Ex-Mogger!
Does the engine turn over? If so unlikely to be immobiliser circuit.
If not check out the ring sensor that sits on the ignition barrel, make sure it somehow has not come dislodged.
If it does turn over use a can of quick start in the air intake past the filter.
Mark - No Longer driving
Spark, Air, Fuel or Compression...
If it's turning over, it's got to be one of the above hasn't it?
Fuel pump relay? Fuel pump not delivering the right pressure? Saw this :
https://youtu.be/cLhM4aNafd8
+8 4.8
Colin - yes I know that timing is unlikely but I would also double check it along with fuel and spark. You can't rule out "interference".......
That was my thought but I do not know if the engine would still turn over when the ring sensor it not picking up the signal from the key. Could be a broken wire or bad contact in the sensor wiring too.
Fred D Offline OP
Again, many thanks to all who have replied. To clarify and reiterate: the engine turns over nicely;the pump does not come one when turning on the ignition (the pump is not broken as I can get it to operate via jumping);all fuses and connections are clean and intact, and resetting and/or jumping the ineria switch did not fix the problem. I would think that there would be pressure in the fuel rail because I operated the pump by jumping it, so it doesn't imply the pump was activated by the ignition, and by extension, the fuel pump relay may not be functional. The shippers did not disconnnect the battery to my knowledge. The battery was a bit weak on arrival, perhaps because the shipper had made so many attempts to start the car, but nonetheless the engine turned over reasonably on arrival.
As was mentioned earlier, I am wondering now if the multifunction relay is bad as it seems as if that would explain the lack of power to the pump with ignition, the lack of starting with the pumped jumped and providing fuel, and the inability to communicate with the ECU?
This is the relay from Lucas SRB501 I always carry a spare.
http://www.ebay.co.uk/itm/1541-Jaguar-XKE-Lucas-SRB501-Replacement-Fan-Relay-/221138177474
Cheaper and it provides you with the Bosch and Hella equivalent numbers.
http://autoelectricalpartsuk.co.uk/products/Relays,_Solenoids_and_Flasher_Units/12V_Change-Over_Relays/Durite_12V_Mini_Change-Over_Relay_072812.html
2009 4/4 Henrietta
1993 Connaught Green +8 prev
http://www.totalparts.co.uk/search/for/bosch+relay/
This is the fuel pump relay - the one above (previous post) is the fan control relay and it's worth carrying a spare of each.
2009 4/4 Henrietta
Fred D Offline OP
The relay I am now thinking may be bad is the multi-function relay module (part YWB100820L) as it not only controls the pump but powers the ECU. I am not sure, but I don't think the above relay is part of my car's system.
Sorry to mislead you - you have a newer car than me so maybe it's this one I've not seen one of these.
http://www.roverparts.com/Parts/YWB100820LG
2009 4/4 Henrietta
