1 members (GLLOQ), 209 guests, and 32 robots.
+8Rich 96
John V6 52
Topics49,897
Posts838,018
#381546 01/08/16 09:00 PM
Hi everyone
Along with the cosmetic and parts I plan on fitting I have one that is more maintenance to do. As my radiator has a small drip from the top pipe to the filling cap. So im looking at a replacement.
Has anyone fitted the Mullberry fabrications one and is it worth the extra money?
My other small question is regarding the fuel gauge. When I have a full tank it reads between 3/4 and full (its to the brim) from my land rover days I would have lived with it or been told that 'they all do that sir'. Is this something that can be corrected though?
Cheers Tom
sailingtom #381548 01/08/16 09:18 PM
There are a number of threads re: fuel gauges. The one on my 90 is far more accurate than on my 4/4. I go by mileage on the Morgan (reset trip every fill).
As for the rad, if you've bought a car with the plastic inlet/outlet pipes then going for a Mulberry rad makes sense. If your car is post '06 (4/4 or +4) Williams also do an ally rad...
sailingtom #381595 02/08/16 06:01 AM
Thanks Graham
Regarding the fuel sender will the same one the 3 wheels are fitting work? Im guessing its the same part across the range.
Cheers Tom
sailingtom #381648 02/08/16 09:53 AM
Not sure about the fuel sender Tom.
BHM or other dealer should be able to answer that one. However, I doubt it will make your gauge any more accurate... smile
sailingtom #381661 02/08/16 10:34 AM
Tom ,
Mulfab rads are the way to go.
sailingtom #381664 02/08/16 10:49 AM
Tom
That leak from the overflow outlet is one of the two classic places the rads fail. Peter Mulberry at Mulfab have the perfect solution for you. Fitted by many owners for peace of mind even before they fail as the OE rads have a very poor reputation.
Same story on +4's with the plastic rads.
BR Colin
sailingtom #381668 02/08/16 11:13 AM
The original rad failed on my 2008 4/4 with sudden loss of coolant out of the top hose plastic union. Noticed when the temperature suddenly began to rise to about 105degC.
Mulfab alloy rad since fitted has been good ever since and worth the cost, especially if you are planning to tour. sherlock
Disappointing that MCC seem to be cutting quality corners and reinforces the notion that its better to purchase a well sorted second hand motor.
Graham
Octogenarian - (83)
1.8 4/4 Ivory
Toyota Yar.
VolvoV70
sailingtom #381699 02/08/16 02:05 PM
GaB
Unregistered
GaB
Unregistered
I had a Sifab radiator upgrade recently, and I am very pleased with it Tom.
I had a small weepy, and decided to go for an upgrade rather than a straight replacement - there is little in the price difference.
The Sifab version is larger and sits on longer bottom mountings.
The engine runs 10 degrees cooler for it.
I am looking forward to a long life with it!
#381715 02/08/16 02:43 PM
As well as the car?
Best Regards
Lang may yer lum reek
As well as the car?
Well I do try to offer a complete solution to customers.....
Simon @ SiFab.co.uk
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
