8 members (CooperMan, Luddite, Hamwich, Mike D, Martin W, PaulV, verysideways, Chris Cosher),
401
97
Topics49,866
Posts837,600
Posts: 541 |
I'm looking at a 1989 propane powered 4 Roadster converted by Isis importer back in the day. It's a very clean car stored inside with has less than 4,000 miles on it. Besides all the seals leaking from sitting would this be a good car to have. I think I can pick it up for around $30k US.
What are your thoughts?
Thanks, Timothy
1998 +8 SS Sport tuned exhaust
2013 M3W Stage ll motor kit Cats removed
Posts: 27,816 Likes: 749
Posts: 27,816 Likes: 749 |
button on here has converted a car back from LPG to petrol. If it has sat for a long time & the mileage would suggest that then it needs a thorough review for seals etc. This might help http://www.mossmotors.com/SiteGraphics/Pages/out_of_storage.html
Posts: 1,500 Likes: 2
Posts: 1,500 Likes: 2 |
Timothy, I would think it would be a great car, only if converted back to gasoline. I had a propane 4/4 for 35 years but it is now on gasoline. On propane, it will only be good around town. If you have visions of travels out of town, you will need to convert it to gasoline.
Having converted three Plus 8 and a 4/4. The conversion is not hard (nor all that expensive) but is better done with a lift (to get the propane tank out from below). 4k Miles on Propane is break in mileage.
Cheers,
Mark
1934 SS MX4 1938 Series 1 DHC 1951 Plus 4 2005 Roadster
Posts: 541 |
I also should add that it is an all steel body no alloy. Would that make a difference, plus or minus? The weight savings is what 100 LB with the alloy?
Thanks again, Timothy
Timothy, In my opinion it wouldn't matter. Other than current rust, having had a steel body should not matter. If there is no current rust, it should be fine going forward. I wouldn't worry about the relative weight, as the weight savings that will come from jettisoning the propane stuff is huge!! More if you remove the some of the regulatory stuff like the high bumpers with shock absorbers, etc. All this will easily eclipse the added weight of the steel.
Cheers,
Mark
Posts: 8,646 |
Buy it. It'll be a gas
Giles. Mogless in Paris.
Posts: 463 |
Dave 98 +8 Corsa Red 74 MGB Red
Posts: 28,901 Likes: 352
Posts: 28,901 Likes: 352 |
Go for it Tim!  Might take a long time to find another...
Posts: 1,943 |
No I have not done this Yet. I have observed several others that have accomplished this Conversion. Button Seattle
Button
Posts: 37,429 Likes: 978
Posts: 37,429 Likes: 978 |
Sounds good at the price Tim.
One advantage of the steel wings over aluminium is they are far less likely to suffer starring from picked up stones in the tyres.
Good Luck.
