2 members (DavidR, M3WMW),
200
33
Topics49,911
Posts838,149
Posts: 27 |
My plus 4 has now done 5000 miles. It had the 1000 mile dealer check and then a 1 year service at the dealer. It is now 2 years old. I have greased the front suspension every 600 miles, checked the spark plugs, chain lube spray on rear springs and obviously regularly checked fluid levels etc. I only run it on shell nitro plus and the oil is still clear golden colour. So the question is: When does it need an oil change and filter change? Is semi synthetic the correct lube?
Dave Wilson
Posts: 490 |
Hi Dave, I have a 3 year old plus 4 with a Duratec engine like yours (you'd better check that, it could be a GDI). I have just purchased all the bits and oils required for a full service. I have only had the car 6 months and this will be the fourth time it has been serviced. It has 7400 miles on it, I am servicing it because I like to know that everything has been done, as a baseline. I would suggest you service it every year unless you do more than 10000 miles a year, that's oil and filter. The gearbox and axle have a longer service interval but I do those at the same time, its only the cost of the oil. Here is a list of what I purchased hope it helps.
Engine: Castrol Magnatec C3 5w/40 fully synthetic 5.8 litres inc filter.
Oil Filter: Fomoco 1751529 AA6E 6714 AA P926D
Air Filter: Fomoco 1216907 1S719601AB
Gearbox: 1.7 litres Total 75w/90 9FE fully synthetic
Axle: Castrol Syntrax L.S.D SAE 75W140 Synthetic Gear Oil 1.5 litres The axle on my car is a LSD.
Prop shaft has 2 grease nipples, rear is easily accessible front difficult. Front suspension has two grease nipples each side top and bottom.
"Hasta la victoria siempre"
Posts: 1,947 |
At that sort of mileage, no need to do it any more often, but I would recommend a yearly socket set tour* and inspection. It's quite surprising what can work loose on a Morgan.
* Socket set tour, a tweak where needed and a look for loose nuts and bolts
Posts: 3,482 Likes: 42
Posts: 3,482 Likes: 42 |
Tefistar -- I also have a duratec Plus4 with a L.S.D rear axle. I experienced some nasty sounds from the dif having put in the Castrol LSD syntrax oil until I put in 75ml of redline friction modifiers. I was told by Castrol that the U.K. Syntrax doesn't contain friction modifiers, only that sold I Aus does as it was made for the Dana Spicer axles for Holdens!!!!! Guess what Morgan use - yes, Dana Spiser axles. Anyway once I put in the friction modifiers, all was well again!!
This may not apply to your oil, but just in case!!!!!
Cheers!
Posts: 2,781 Likes: 5
Posts: 2,781 Likes: 5 |
Dave, my GDI has done a similar mileage to yours. I change oil and filter every year, technically it doesn't need it on mileage but I like to know its done. In the first year I have changed g/box and diff (LSD) oils, checked plugs and cleaned the air filter. Levels are checked and suspension and prop (not too often)greased regularly.
I also do a visual, spanner and fittings check almost on an ongoing basis, even things like side screen bracket screws come loose.
I have also adjusted front hubs after initial running in they had some slack. Brake fluid I think i'll do year 2 too.
Steve 2008 4/4 1.8 Duratec
Posts: 490 |
Hi Robbie, Oh, thanks for that. I got my information from GOMoG here http://www.gomog.com/allmorgan/axlefilling.html#GreasingFilling a BTR axled Morgan, Fluids for LSD BTR's. It says that it already contains a friction modifier (Sturaco), so I'll see what happens when I change it. Thanks, Peter
oh and I used Mobil 1 for eng and Millers fully synth from Opie for box and diff. Ignore the handbook that says you need 1 ltr in the diff, its 1.6
Posts: 490 |
Just went to look at the handbook again for reassurance and it says that the 4/4 should have 80w/140 fully synthetic oil, the Plus 4 80w/140 semi synthetic oil, roadster 80w/140 semi synthetic and the plus 8 80w/140 synthetic oils of the highest quality. Anyone know why the 4/4 is different, I am sure I read somewhere that all the axles across the classic range were the same except for the ratios. I think its a misprint. The Castrol Syntrax that I have got is the most expensive oil I have ever bought £15 a litre. Confusing or what?
Posts: 327 |
I guess you have a Mazda MX5 gearbox, perhaps you should consider Mazda recommendations for gearbox oil.
