0 members (),
281
37
Posts837,277
Posts: 1,737 Likes: 55
Posts: 1,737 Likes: 55 |
I bought my car second hand and is fitted with the boot liner. Are they standard issue? Does one need the rear mudguard as well as the liner? The boot liner is standard. Personally I would always recommend fitting an internal mudguard as well. It's amazing what a state things get into under the boot liner without it, especially if you ever drive on wet & muddy lanes.
Andy
Posts: 1,338 |
You guys forgot the oil cap gasket. Its a must.
Posts: 286 |
Bear in mind some of these relate to older M3W's so I'd suggest that you do just drive and enjoy it for a few days before getting too hung up on "fixing" things. In particular: Check the Fuel Hose clamps on the Throttle Body hoses. I believe these are now improved from the original design so should be OK.Make a PVC cover for the vent hole in the steering rack. Probably not required - maybe a squirt of ACF-50 at some time.
Paint the bare metal part behind the engine where the steering column and steering rack join. ACF-50Plug the hole in the compensator housing. Don't bother! It may not even still be there with the current standard Centra unit.
Weatherproof the area behind the seats. New cars should now have a rubber seal between the aluminium seat back and the body which will help. if it gets wet it will dry out and then worry about further waterproofingPaint the inner front fenders with chip-proof paint. It won't do any harm but mine are still OK unprotected after 10,000 milesReplace the long bolt that prevents the easy removal of the steering wheel. Enjoy looking at it and driving it first - you've certainly waited long enough! This, +1. I'm one to savor my pleasures..especially those I've anticipated... and not ruin it with the nits. There's time enough for that when they crop up. I did indulge in a detail...I like to rub the things that excite me...and a coat of Leather Honey. And, a Moto Lita 15" 4 spoke wood wheel install and Uncle Mel's engine turned dash panels. Enjoy your car...you especially, given the amount of agita you've been thru! Also, if we're talking single malt,....the perfect congratulatory beverage...might I suggest something far less iodine like Balvenie Double Wood?
Posts: 37,403 Likes: 977
Posts: 37,403 Likes: 977 |
Where is the sense of adventure surely someone has made love in one
Posts: 241 |
Where is the sense of adventure surely someone has made love in one I think I've "broken in" every car I've ever owned. The M3W? I imagine you make love with some part of you body in it, but you don't make love in it.
Posts: 2,539 |
Where is the sense of adventure surely someone has made love in one In, probably not. Against?... much more likely, but i digress...
Where is the sense of adventure surely someone has made love in one I think I've "broken in" every car I've ever owned. The M3W? I imagine you make love with some part of you body in it, but you don't make love in it. I was just wondering if any of you guys had managed - you have already proven how adventurous you are by owning one and as you say some things have to be done.
Where is the sense of adventure surely someone has made love in one In, probably not. Against?... much more likely, but i digress... Enjoy your car when you get her  .
Posts: 5,210 |
Where is the sense of adventure surely someone has made love in one I think I've "broken in" every car I've ever owned. The M3W? I imagine you make love with some part of you body in it, but you don't make love in it. I was just wondering if any of you guys had managed - you have already proven how adventurous you are by owning one and as you say some things have to be done. To do it Richard, you'd need about four knee caps on each leg!
Where is the sense of adventure surely someone has made love in one I think I've "broken in" every car I've ever owned. The M3W? I imagine you make love with some part of you body in it, but you don't make love in it. I was just wondering if any of you guys had managed - you have already proven how adventurous you are by owning one and as you say some things have to be done. To do it Richard, you'd need about four knee caps on each leg! I think that would kill the passion Roger, the pair I have have seen better days...
