Topics49,837
Posts837,291
Posts: 836 |
those adapters should come on all cars, they are a genius thing. The only pitfall is that someone could come along and drain your oil without using any tools...unlikely though.
Posts: 1,490 |
Well, what I did in the first week I had mine was about 800 miles, an oil change and then drove to Holland in a torrential downpour just before Christmas. I did cheat and take a boat for the bit across the North Sea. Wimp!
The Original Ken 11,000 miles.
2014 BMW R9T 2005 Saabaru 2005 Saabaru
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
It would be nice if my oil tank had a drain off!
Posts: 902 |
I don't know why Morgan changed the cap. On my 2012, the cap with the dipstick, there is a recess inside and an "O" ring inserted. Seems to be one thing they did right on the first 3 wheelers. I don't see why you can't have the o ring recess machined in to all the newer caps---Mine doesn't leak a drop. Are these oil caps still around or have they all been swapped out? Do they fit the later style oil tank?
Posts: 245 Likes: 5
Posts: 245 Likes: 5 |
Carry a fuel pump and know how to fit it
Posts: 241 |
Carry a fuel pump and know how to fit it I've seen this posted a couple of times on the forums. Just how big of a problem is this?
Posts: 2,539 |
Carry a fuel pump and know how to fit it I've seen this posted a couple of times on the forums. Just how big of a problem is this? it is hard to tell exactly, I know 3 or 4 people here on the forms have had those fail, the problem is there are probably getting close to 1500 3 wheelers on the road of which we have maybe 200 here on the Forum probably less, and out of that 3 or 4 failures.
Posts: 462 |
I'm not sure its a big issue? I have had on problems there. I would carry a tool kit, spare oil filter and a spare drive belt. After that you would need a trailer to starting carrying everything that could go on the "Fritz"
JV Sclafani Boca Raton, FL '13 M3W Metallic Orange Pearl 128CI Steered by Empire - Riding on Ohlins
Posts: 1,370 Likes: 11
Posts: 1,370 Likes: 11 |
I'm not sure its a big issue? I have had on problems there. I would carry a tool kit, spare oil filter and a spare drive belt. After that you would need a trailer to starting carrying everything that could go on the "Fritz" Tools are good. A combo ratchet with metric and english is nice. Spark plug socket to fit same. Needle nose pliers. Allen head set. English and metric. Electrical tape. Duct tape! Standard and Philips head screwdrivers. Zip ties. Forget the oil filter and drive belt. An extra liter of oil is good. Changing a drive belt requires a small lift, an adjustable 350mm spanner, a cotter pin and patience. The drive belt will not break. Those gates models should last at least 50,000 miles. The cambelt, without the spacer set to help cool it, will have a shorter life. If you want to carry one at considerable cost then also add some steel 3/16" shafts about two inches long. You'll need them to swap in a new one. Loctite! Basically, if anything happens to the tires on the front or the single car tire in the rear, you'll be towed. A spare rectifier just might be a good idea still. I don't know the current failure rate for the Cycle-Electric model used in the new position. My H-D unit in the original position has 27,000 miles on it. Seems ok. Exhaust bobbins! Get more. The rectifier has a few you can steal in case one of the muffler units sheers. They're cheap and small. This has been a point of failure. That is all I have.
Posts: 902 |
Plus, Allen screws everywhere and secure torx. Puncture repair kit, like this. Can of mousse for tyre inflation or pump.
