Morgan Aero 8
1 members (+8Rich), 284 guests, and 32 robots.
+8Rich 95
John V6 49
Posts837,992
rockabilly john
#384618 12/08/16 06:30 PM
Geordie Offline OP
Hi , is there a visual difference on the rear tailpipes, if a standard or sports exhaust is fitted on the latest model ?
Cheers
Graeme
Geordie #384679 12/08/16 09:04 PM
I was told no. The difference is in the noise! Perhaps the experts on here can confirm or otherwise?
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
Taffmog #384684 12/08/16 09:20 PM
Formerly known as Aldermog
I was told the difference is the silencer...the sports ones are shorter.
Geordie #384688 12/08/16 09:35 PM
Geordie Offline OP
Thanks, the reason I ask is because our car has arrived at the dealer & on starting it the sound isn't as I remember when I drove the factory demo.
Graeme
Geordie #384705 13/08/16 12:21 AM
I'll measure my (sport) silencer if it helps!
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
Geordie #384730 13/08/16 06:30 AM
Here we go, i will measure mine.
Martin (Deano)
Geordie #384757 13/08/16 09:23 AM
Hi Graeme,
I've measured mine....22inches/56cm.
Mine are definitely sports silencers and sound quite loud. I had reason to remove one and discovered that the central tube is 'straight through' with a slight offset between front and rear of the can and a perforated section in the middle.
Mine is a rear exit system with twin stainless tailpipes each side.
Hope that helps,
John.
2015 Metallic Claret Red Aero Plus 8
Geordie #384768 13/08/16 10:04 AM
My side exit silencers are 40cm.
Martin (Deano)
Geordie #384787 13/08/16 12:20 PM
Smile, it confuses them
I thought the sports part meant cat/exhaust box amendments. Hence you could have a rear exit _sports_ option ?
Geordie #384798 13/08/16 01:22 PM
Geordie Offline OP
Thanks for the help. As a £1560 extra I would think it must be a whole exhaust system ?
