1 members (Kolvites),
328
45
Posts837,990
Posts: 58 |
Hi , is there a visual difference on the rear tailpipes, if a standard or sports exhaust is fitted on the latest model ?
Cheers Graeme
Posts: 2,433 Likes: 17
Posts: 2,433 Likes: 17 |
I was told no. The difference is in the noise! Perhaps the experts on here can confirm or otherwise?
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
I was told no. The difference is in the noise! Perhaps the experts on here can confirm or otherwise? I was told the difference is the silencer...the sports ones are shorter.
Posts: 58 |
Thanks, the reason I ask is because our car has arrived at the dealer & on starting it the sound isn't as I remember when I drove the factory demo.
Graeme
I'll measure my (sport) silencer if it helps!
Posts: 5,659 Likes: 10
Posts: 5,659 Likes: 10 |
Here we go, i will measure mine.
Martin (Deano)
Posts: 124 |
Hi Graeme,
I've measured mine....22inches/56cm.
Mine are definitely sports silencers and sound quite loud. I had reason to remove one and discovered that the central tube is 'straight through' with a slight offset between front and rear of the can and a perforated section in the middle. Mine is a rear exit system with twin stainless tailpipes each side. Hope that helps, John.
John 2015 Metallic Claret Red Aero Plus 8
My side exit silencers are 40cm.
Martin (Deano)
Posts: 11,535 Likes: 321
Posts: 11,535 Likes: 321 |
I thought the sports part meant cat/exhaust box amendments. Hence you could have a rear exit _sports_ option ?
Posts: 58 |
Thanks for the help. As a £1560 extra I would think it must be a whole exhaust system ?
