SORN
New
Topics48,371
Posts813,487
Members9,215
Posts: 26,766 Likes: 427
Posts: 26,766 Likes: 427 |
I understand on later cars the kit won't work due to the screen pillar design.
Posts: 1,749 Likes: 13
Posts: 1,749 Likes: 13 |
well done Stewart - looks great  If you are going to be removing the wipers on a regular basis, it may be worth investing in something similar to this - https://www.amazon.co.uk/Neilsen-Battery...en+wiper+pullerMixed reviews, but people seem to mostly have problems where the wipers are seized on;there is another , simpler version available too. It can be really all too easy to mess up the splines on the wiper shat if you get the angle wrong... James
Aero8 , Series 1 - Boston Green Mercedes EQC 400 AMG Smart Brabus Convertible Honda Monkey Z125
Posts: 14,009 |
I understand on later cars the kit won't work due to the screen pillar design. Correct John. The later alloy pillar cars but also later cars still with the stainless uprights. It's all down to the angle of the tumblehome of later screens ........post 2008? I know that the kit would not fit my 2010 4/4 Sport. Stewart....lovely job! You can get nice chrome caps to cover your wiper splines. I'm looking forward to seeing the aeroscreens on....I'm a great fan. I fitted them them to my 4/4....as John says, take care in placing them. I used penny washers under the alloy scuttle to cut down the risk of stressing the alloy.
Posts: 11,610 Likes: 43
Posts: 11,610 Likes: 43 |
well done Stewart - looks great  If you are going to be removing the wipers on a regular basis, it may be worth investing in something similar to this - https://www.amazon.co.uk/Neilsen-Battery...en+wiper+pullerMixed reviews, but people seem to mostly have problems where the wipers are seized on;there is another , simpler version available too. It can be really all too easy to mess up the splines on the wiper shat if you get the angle wrong... James top tip thanks, I've just ordered one as i had a 'play' late last night after the posts on here about taking the wipers off and in 5 minutes of struggling, gave up for the night (it was past midnight as was tired)
OXR 5 L - Learner Plates On
Posts: 209 |
I think if I were doing this, I would fit a switch into the wiper circuit, it would save having to carry and re-fit the blades when needed.
Tony
Posts: 1,148 Likes: 18
Posts: 1,148 Likes: 18 |
I have a folding windscreen on our series 1 flat rad one problem we have found which side does the rubber seal go to allow screen to fold ours is inside is that correct? Seems very tight and could detach from Base of windscreen if forced!
Morgans 1934 MX, 1947 Series 1, 1956 +4 TR4, 2000 +4 T16 Triumph Herald 1969 13/60 Morris 1970
Tony That's not a bad idea - could be just a simple switch mounted under the bonnet
Posts: 764 Likes: 8
Posts: 764 Likes: 8 |
Stewart re the puller.. does the wiper arm cap fold back exposing a ring that slides on the wiper splines or is it just a rigid cap that is simply pulled off? If its a pull off cap then the puller has no spindle centre to push against (like a hub puller). Perhaps it may help grip though? Just thought on leaving wipers on, are the blades resting on the scuttle paintwork or floating unsupported? I personally take the wipers off, but mine are removed with a centre screw that tensions an ally wedge on the splines, so there are clearly different systems, the screw type may be available somewhere.
1993 T16 +4 Lancia Blue.
Posts: 1,415 |
Great work - you pull the chrome/stainless cap from the splined shaft, try and hold it as parallel as you can otherwise it doesn't want to come off is my experience. Make a mental note or mark the shaft relative to the arm as it will save the trial and error when refitting, it's easy to scuff the screen surround otherwise when the wiper over sweeps. So the wiper arm just pulls off ? Not quite... Loosen the screws immediately next to the three spindles. This screw is attached to a wedge that pulls the wiper up tight on the wheel box splines. No need to take them all the way out. Just back them out 2-3 turns. With the screwdriver still in the screw slots, give the screwdriver a tap back down towards the scuttle with the palm of your hand. This knocks the taper wedge back down and away from the wheel box spline Angle the arms up 90 degrees against the tensioning springs as previously mentioned Then the wiper arms can be simply removed Simon @ SiFab.co.uk
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Posts: 764 Likes: 8
Simon thats if you have screws, stewart clearly has none, fish yes, screws no..
