0 members (), 301 guests, and 34 robots.
+8Rich 93
John V6 49
Posts837,990
Page 3 of 6 1 2 3 4 5 6
Gambalunga #386004 17/08/16 10:41 PM
Nice for Vitesse to come back to you so promptly Peter.
I was in work today but two virtually back to back tours and a three wheeler test drive gave me no time to ask about the gearbox tunnel or extension. At least the later has been solved....ill ask about the tunnel remove issues tomorrow.
On my 4/4 I did try to remove the cover and gave up as the front was heavily glued to the bulkhead with silicon sealer!
Gambalunga #386006 17/08/16 10:58 PM
Sorry to hear this Peter - I was away for a long weekend watching young Matt Hall win the English leg of the Red Bull Air Race when you started the thread.
You seem to be getting some sensible assistance with the problem which is reassuring.
Good Luck with the tunnel, they booked me 1/2 a days labour at a garage in Exminster when they took my seats and tunnel out to replace the handbrake cable on the Sport.
Gambalunga #386010 17/08/16 11:17 PM
Sounds promising Peter.
Gambalunga #386035 18/08/16 06:27 AM
Good news Peter. I hope it all works out for you.
Gambalunga #386036 18/08/16 06:29 AM
Pictures are essential!
Gambalunga #386038 18/08/16 06:30 AM
That's good news Peter ...keep us posted!
Neil
Robbie #386073 18/08/16 08:31 AM
Originally Posted By Robbie
Best of luck with removal of the trans cover, Peter. Hope you'll be back on the road soon!
Cheers!
+1 - hope to meet you in Italy with the Morgan soon! thumbs
Brian
2014 Morgan SP1 (Rocket Red)
Gambalunga #386110 18/08/16 01:11 PM
To give some update on this I managed to remove the suspect part.
1. Seats out
2. Remove the padded gearbox cover
3. Remove all screws
4. Discover that the transmission tunnel sits over the gearbox cover!!!!????
5. Peel back leather glued to the transmission tunnel
6. Remove all screws and remove transmission tunnel
7. Climb into car and attempt to raise gearbox cover
8. Use large screwdriver and hands to pull and lever the cover away from the glue/sealant, climb back into car and lift the rear of the cover.
9. Work the cover back and discover tha it can't be lifted over the brake lever and is restricted by the upturned edge at the front fouling against the bottom of the heater box.
10. Work through the gaps to remove the 4 bolts holding the remote gear lever case to the top of the gearbox.
11. Remove remote spilling oil on the carpet that would be under the seat frown doh (I should have kept it tilted upwards and I should have had some rag under it as I removed it)
12. Remove carpet and wash out the oil with copious quantities of detergent - hang carpet to dry.
13. Dismantle remote case, photograph and email description and photos to Vitesse
14. Head back up the mountain for a well earned beer.
After a few emails backwards and forwards to Vitesse it is starting to look as though the problem may not be in the remote gear lever extension even though it is one of the earlier versions (2011) without welding. It is not yet definite but the problem may be in the selector mechanism of the gearbox itself. If this is the case it is an engine and gearbox out job. I will know for sure in the next day or so.
Vitesse tell me that if this is the case it is extremely unfortunate as it would be the only case of gearbox failure in over 6,000 gearboxes that they have supplied.
I have to say that Vitesse have been fantastic in all this with prompt and helpful replies to my emails. I wish all businesses were as correct and helpful. Judging by this I can only say that anyone considering a gearbox conversion for an MG or one of their other products, including the Morgan Plus 4 automatic conversion, should have no concerns about aftersales support.
https://www.vitesse-ltd.com/blogs/news/110594119-automatic-for-the-people-morgan-plus-4-automatic
View of the top of the gearbox with remote extention removed.
The mating actuation lever in the remote extension.
The remote extention case opened.
Another view of the internals. The item on the bottom left is the end of the gear lever itself.
Gambalunga #386117 18/08/16 01:37 PM
If you can find an exploded view of the box internals it may become more obvious what's gone wrong. It looks like a single rail selector so it points to the location of the selector forks on that shaft. First/Second conventionally share a fork so if it won't come out of second it suggests the problem is there.
I only have limited experience of three rail gearboxes so that's all I can add.
Gambalunga #386127 18/08/16 02:09 PM
Peter good luck with this. I too hope you are back on the road soon.
