7 members (JMcL, cerealsurfer, RichardV6, RedThree, simon8201, Dek, AlyMatt),
307
Posts837,985
Posts: 199 |
WoW WoW, long long time i haven't see such approximative piece (in some R8 Gordini we have similar **** job)
based on the vid & pic's you will need more than just Teflon spacer you also need a tiny tube around the screw , and also a cylinder around the lower tube.
If you need i made you a sketch for understand better my FranGlish let me know
Posts: 14,749 Likes: 158
Posts: 14,749 Likes: 158 |
If I understand correctly what I am looking at it is actually a remote linkage. Most likely the concept is similar to the remote linkage that sits on top of the Mazda box in the 4 cylinder cars. There is a big difference in the remote built by Vitesse that you can see in the picture below. The difference is that the Vitesse unit is in an enclosed case, bathed in oil, and uses nylon bushes. All in all tight and well engineered.
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
I did wonder why the pivot point was resting on the threads the bolts shoulder isn't long enough I will source one with a better fit and function the forked part is sleeved each side but the centre pivot hole isn't almost like an m6 in an m8 hole but probably imperial equivalent.
I may have to consult the drawings from factory to see what should be fitted!
It was your woes that prompted me to look at mine Peter.
The vitesse unit looks like a much better solution.
This may be a Ford part in totality as the bush at the back has a Ford stamp in it.
Posts: 27,835 Likes: 759
Posts: 27,835 Likes: 759 |
True you don't need to change gear much. I find third is the fun one.
Posts: 1,075 Likes: 1
Posts: 1,075 Likes: 1 |
Posts: 367 Likes: 1
Posts: 367 Likes: 1 |
Mark I will be very interested to see what the end result looks like. The gearbox on mine is the one thing that would make me change it, when it's really being a pig. Andy
Unfortunately rain has stopped play here today, I was going to take it out for a bit of a run then the heavens opened up big time so I thought it could wait as I can't be bothered to put the roof up
Posts: 14,009 |
It would be interesting to see what alternative gearbox options there are and how easy it would be to change.
It would be interesting to see what alternative gearbox options there are and how easy it would be to change. Every so often I wonder how an auto with paddles would be but every time I think of it I decide I just can't see it in a trad. I would be happy with an auto box in an Aero but I would never consider an Aero (or Plus 8) for various reasons. Wouldn't it be great if Morgan produced something along the lines of an Aero with an affordable 6 (or perhaps even better a turbo 4) putting out 250hp with an auto, paddle shift, traction control and ABS (if you have ABS you might as well have traction control too). I know to some that this is blasphemy but I'm sure there would be a queue to place orders if it could be done at a reasonble price. Oh! And whilst they are doing the design they could ditch the weird forward opening boot and design an "easy-up" concealable hood (or pinch the design from Mazda/Fiat)
