13 members (TomS, DMC1904, JD44, +8Rich, Grumpy2, MDS61, MJF, The Flitting, asterix, BLUE+4, mph, John07, Graham, G4FUJ), 301 guests, and 45 robots.
+8Rich 64
Adam12 62
John V6 58
9,215 Registered Users
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,364
Posts813,336
Members9,215
Page 6 of 6 1 2 3 4 5 6
Drop the tank? Undo the supporting board, support the tank and slide out the board, lower the tank...
I drop the tank as stated. Removing it thru the top is a PITA. First the back deck must be removed. than the spare tire rack. It is too easy to drop the tank out the bottom.
Button
Seattle
Button
E
E
Ken
Thanks so there is no glue involved?
E
E
I don't want to drop the tank- just take the sender ( white with Black plastic ring) out to replace fuel pressure regulator
Re the "gizmo"
I agree with PaulJ that it's the fuel pressure regulator. I've just had another look at the parts book and looking at the way things are piped it must be. This would also be why you have high pressure fuel in the return line.
Unfortunately the parts book just says "fuel pump" for all the kit that goes in the tank and does not break it down any further.
Cheers
On My Morgans the spare tire rack is bolted with 4 bolts on each side to the cheek boards on the wheel arch. Maybe if You remove these 4 bolts You can get enough "wiggle" room to access the fuel pump. Just an idea. Never have done this myself.
Button
Seattle
Button
U
TM Photographer of 2008
U
Ken
If there is you'd have to remove both horizontal battens. Try removing the lower one first and see if it pulls apart. If it doesn't you know it has been glued together.
Ken
E
E
Originally Posted By John07
Re the "gizmo"
Cheers
Thanks trying to source a "new" replacement pressure regulator.
