7 members (Bilymog , JohnHarris , sprinty , verysideways , aerotaff , TalkMorgan , Bishmog ),
201
44
robots.
Admin ,
Global Mod ,
Posts837,962
Most Online1,063Jun 14th, 2026
just an little update on the folding screen I did the test fit and it went really well as you saw in the earlier photos The reason it was a test fit was that I knew I had to make some adjustments to the folding screen brackets as I have the easy up hood from 2000 which requires a tall side bar and retaining slot to fix the hood top rail So today I had my metal basher's (they have the equipment for a straight and perfect cut) to cut the top of the original bar and the top off the folding screen bar so I can merge the two together here it is after the cut was done you can see to align the holes perfectly I bolted the two together I'll fit it tonight and update with a photo I'm going to do the other side tomorrow
screenbarcut.jpg (123.24 KB, 364 downloads) The tape was just to protect the polished steel
There's no going back now then!
No you are right - scary thought
Wish you hadn't of reminded me
Good luck and I look forward to the results.
Richard 1976 4/4 4 Seater
Stewart , where did you buy the folding screen kit ? (sorry if i miss this information)
Just a little update Yesterday I fitted the two part windscreen side supports The cutting blade was 2.5mm but I seem to have got a 3 mm gap but I polished off the edges with my Work Smart Knife sharpener The old side supports were in a brushed finish and the new are highly polished which doesn't quite marry up but I don't think it looks too bad
Also The wiper bezel covers from John at Heart of England Morgans came the other day so I had a 'play' I took one wiper off and fitted one to have a look - rather groovy
Do you have permission to mess about with your car on a Bank Holiday weekend Stewart?
Sorry if that invites an insignificant #5000 post........
Suggest you hold your fire, if that's possible.
They will cause a smile at your next MOT.
Martin (Deano)
