3 members (SwissMogFan, moggywills, RedThree), 202 guests, and 48 robots.
+8Rich 83
Luddite 50
Posts837,946
Page 5 of 14 1 2 3 4 5 6 7 13 14
just an little update on the folding screen
I did the test fit and it went really well as you saw in the earlier photos
The reason it was a test fit was that I knew I had to make some adjustments to the folding screen brackets as I have the easy up hood from 2000 which requires a tall side bar and retaining slot to fix the hood top rail
So today I had my metal basher's (they have the equipment for a straight and perfect cut) to cut the top of the original bar and the top off the folding screen bar so I can merge the two together
here it is after the cut was done
you can see to align the holes perfectly I bolted the two together
I'll fit it tonight and update with a photo
I'm going to do the other side tomorrow
The tape was just to protect the polished steel
There's no going back now then!
Roger
No you are right - scary thought
Wish you hadn't of reminded me
Good luck and I look forward to the results.
Y
Y
Stewart , where did you buy the folding screen kit ? (sorry if i miss this information)
Just a little update
Yesterday I fitted the two part windscreen side supports
The cutting blade was 2.5mm but I seem to have got a 3 mm gap but I polished off the edges with my Work Smart Knife sharpener
The old side supports were in a brushed finish and the new are highly polished which doesn't quite marry up but I don't think it looks too bad
Also
The wiper bezel covers from John at Heart of England Morgans came the other day so I had a 'play'
I took one wiper off and fitted one to have a look - rather groovy
Ray Offline
Looks a bit phallic.
Do you have permission to mess about with your car on a Bank Holiday weekend Stewart?
Sorry if that invites an insignificant #5000 post........ innocent
Suggest you hold your fire, if that's possible.
They will cause a smile at your next MOT.
Martin (Deano)
