6 members (sprinty, B&C Morgan, TBM, Mike D, Sukram, MartinB60), 234 guests, and 32 robots.
+8Rich 94
John V6 50
Posts837,997
rockabilly john
AlexP #388350 26/08/16 01:00 PM
On my 2002 Plus8 the sensor is near the thermostat housing. The thermostat has two small bypass holes in it to allow a small flow through when the stat is closed. When I flushed the system at the last coolant change I forgot to check the stat in a saucepan so can't tell you what it opened at!
The fan switch is in the top tank screwed into a boss. The heat soak leads to a rise in temp there when on stop hence the fan kicking in on hot days in slow traffic etc..
As an aside.... Has anyone filled with Evans waterless? What effect, if any, on the running temp? I know someone who had a new rad and Evans at same time so no feedback on it's cooling efficiency.
sospan #388357 26/08/16 01:29 PM
Oh! No!
Best Regards
Lang may yer lum reek
AlexP #388431 26/08/16 05:50 PM
AlexP Offline OP
thanks all greatly appreciated. I've had issues with fan switch (knackered), fan (now slightly knackered) which makes me want to replace anyway. And now the temp guage is not working hence my need for location of temp sensor... Seems cooling system is a bit on achilles... smile
AlexP #388459 26/08/16 07:45 PM
Don't waste your money
sospan #388528 27/08/16 07:57 AM
[quote
As an aside.... Has anyone filled with Evans waterless? What effect, if any, on the running temp? I know someone who had a new rad and Evans at same time so no feedback on it's cooling efficiency. [/quote]
Now that's an interesting question.......?
Ken A.
Plus 4 2009 Centenary Metallic Red
Plus 8 1994 Dark Green (prev)
Honda CB100 The Big One
sospan #388532 27/08/16 08:15 AM
surrender
Roger
AlexP #388657 27/08/16 06:33 PM
AlexP Offline OP
FYI my temp gauge showing nothing was nothing more than a corroded connection on temp sender fitted in the block. WD40 and right as rain.
AlexP #388664 27/08/16 07:07 PM
Excellent news
So is it actually overheating?
I've replied to your email, but I'm away in the wilds so not sure the carrier pigeon got as far as the Internet.....
Simon @ Sifab.co.uk
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
AlexP #388876 28/08/16 06:44 PM
AlexP Offline OP
nope regulating perfectly. just temp sensor going haywire, which in combo with a knackered fan / fan switch confused me. Got your mail Simon, will reply.
