3 members (RedThree, yobtaf, Luddite), 312 guests, and 79 robots.
+8Rich 83
Berrybrook Aero Plus8 advert
by +8Rich - 31/08/26 04:59 AM
Topics49,850
Posts837,427
SteveH #389042 29/08/16 05:00 PM
That's a good tip Phil ...I will have ago at that !
Neil
SteveH #389055 29/08/16 05:29 PM
SteveH Offline OP
This had crossed my mind . Now you said it as well I'm not sure which ones to go for 🤔🤔🤔
Stingmog
SteveH #389089 29/08/16 06:34 PM
The success of this depends on the colour. Yellow looks really good, but I tried red and it wasn't half as good.
If you have a dark colour it won't show very well.
But a good way to pass an hour or so!
Originally Posted By PhilRoyle
If you go for the Morgan scripted ones - fill in with body coloured paint - looks good & stops the muck getting into the wording.
What an excellent idea.
Best Regards
Lang may yer lum reek
SteveH #389321 30/08/16 03:16 PM
GaB
Unregistered
GaB
Unregistered
Hi Phil.
What kind of paint and process do you suggest to do the in-filling?
I found it easy to do the same with the organ pedal (wide, deep holes), but this looks kind of fiddly.
thinking
SteveH #389334 30/08/16 04:00 PM
I did this today.
I used Chipex paint and applicator.
Overfilled the Lettering - waited 5 mins/Hub ( timed accurately) then carefully wiped off the excess with Chipex Fluid.
Great result - I like it!
Not a massive visual impact - but close up it looks very good (well I think so!!).
And I am pleased ...took about 30 mins ...well tea was also consumed and I took my time!
Neil
NeilL #389338 30/08/16 04:12 PM
had mine painted for the last 4 years. used humbrol acrylic paint. red for the arrows and writing. car colour (Blue) for the Morgan script.
The Car is fast the sky is blue just be safe in what you do
SteveH #389434 30/08/16 09:26 PM
GaB
Unregistered
GaB
Unregistered
Thank you both.
I will try this when I have the wheels off for winter chrome cleaning...
#389606 31/08/16 04:23 PM
I used the body coloured paint I begged from Morgan on my first service and floated it in gently with a cocktail stick. When dry after a couple of days used a number 11 scalpel - razor blade will do - to remove any from the raised bits of the badge.or wheel where it had overflowed a bit. Tape over the nut so as not to get too much on the chrome.
PS - also did the badges as well on the cowl and "boot".
