0 members (),
131
Old Book
Goodwood
Topics49,932
Posts838,511
Posts: 114 |
I'm likely to be refitting my seats this weekend (at long last). I want to replace the nuts bolts and washers whilst I'm there. The old ones are not in awful condition but I might as well, eh?
Question is: should I use BZP or Stainless A2 nuts and bolts? Why?
Neil 1988 Morgan 4/4 4 Seater, black 1996 LR Defender 110, white 2009 Honda Deauville, black
Posts: 22,385 Likes: 358
Posts: 22,385 Likes: 358 |
It doesn't really matter Neil. These fixings are not stressed, so stainless is fine. But if the originals are reasonable, try putting them in vinegar for 24 hours. Clean first with white spirit to remove oil/grease, and they will come up really well. An old restorers trick.
Posts: 413 |
Ok, my seat transformation is done. In the begin i have provisory adapt the seat that he could be back completely. Now i have transformed the high of the seat that he moves without problem, in the same winter works,I have renovated the foam and the flex of the seat, he is now like new. The carpet is replaced (DIY handmade from a doormat) and fixed. Dave thanks again for many ideas, more Adaptations are done or will follow.
Don't Worry, Be Happy Morgan 4/4 1985 2,0 Zetec BMW R1200 GS Triumph TR140
Posts: 413 |
A yes, still a question. All the screws are too long, for the technical inspection(security) the need to be cut?
It's OK to cut the ends off underneath, but might be harder to fix next time!!! (unless you use new long ones & cut again).
Posts: 655 Likes: 12
Posts: 655 Likes: 12 |
I don't think the screws under the must be cut to pass the inspection. If so, I would be in trouble with the original setup.
Harald
Harald +4 4-seater 2008 Squadron Blue
Posts: 413 |
Yes the old one what to short, as Dave said i had to replace them. I Think “wait and see”, in April a have to go
Posts: 1,149 Likes: 19
Posts: 1,149 Likes: 19 |
Hi All, we have a year 2000 plus 4 and the seat bolts are rather long and hit speed bumps why r they so long is it worth cutting down or putting shorter bolts in? Will try the leather touch up looks and sounds great.
Morgans 1934 MX, 1947 Series 1, 1956 +4 TR4, 2000 +4 T16 Triumph Herald 1969 13/60 Morris 1970
You can cut them off Rob but if you need to take the seats out you will probably need longer bolts to get the nuts started. An alternative is to fit some spacer washers under the bolt heads as long as the bolt head doesn't interfere with the seat runners.
Thankyou I'm guessing many folk have these bolts too long and the first to hit speed humps mine must be a good 2 inch over
